HV Cornmoor SD/WRD
HV Cornmoor SD/WRD
This is the final change of idea now for the layout, I have gone back to my origianal plan of a Servicing point and Wagon repair depot set in 2009. So i can run modern locos but also have locos running in for servicing Steam & Diesel off railtours.
So you will see a wide range of locos and liverys on the layout including modern locos & Liverys. so keep watching this thread for regular updates on Cornmoor SD/WRD.
josh
josh
layout thread - http://www.newrailwaymodellers.co.uk/Fo ... php?t=9762.
thanks for the reply i haven't actually decided how i will operate the layout but you have given me some ideas thanks hopefully i should have all the track together and down in a few months because of money constraints.
cheers josh
cheers josh
have got all the track together and have laid it i am going to start laying ballast this weekend will post some pictures at weekend.
cheers josh
cheers josh
really sorry for the late reply but i have know laid all the track and wired it up and put the back scenes on and put some metcalf grey brick on the two sides and the back boards around the layout and i have started to ballast the track which is about the worst part of building the layout will post some pictures this week because im up to the north yorkshire moors railway this weekend.
cheers josh
cheers josh
this are the pictures of my layout really sorry for the late reply i have been really busy resentlly the first picture is an over view of the layout.
the second picture is a second overall view of the layout.
the next two pictures are of a loco that i am using to run the yard at the moment the it is a class 08 shunter and the second picture is a rake of trucks on one of the siding in the yard.
will post some pictures this weekend when some of the ballasting has been done.
cheers josh
cheers josh
- MiniMichael
thanks for the comments wobblybob and minimichael wobblybob i agree with you i hate ballasting that is partly what made be scrap my old layout and start this smaller one.
cheers josh
cheers josh
- MiniMichael
i agree with you the slightist bit of ballast around the power wires where they are solderd on to the track and the layout stops working.
cheers josh
cheers josh
sorry i didn't make that bit very clear it is even before i put the glue down that the ballast shorts out the track so i don't know why.
cheers josh
cheers josh
