pete12345 wrote:Looks great! How long does scribing the stonework take?
A couple of evenings - it's one of those things that once you get into it and discover a technique, you can do it fairly quickly.
A third evening is necessary to do the tidying up work (filling in corners, re-scribing thereof etc).
The scribing is done with a mini counter-sink in a dremel with the 1m flexible extension shaft. Provided the plaster is not too hard (care needs to be taken in the mix and I find mixing wallpaper paste in helps), the scribing is generally quite quick, however, it is a very dusty process, best done in a well ventilated area and definately using a face mask to prevent inhalation.
My first attempt at this method of construction was:
http://mrol.gppsoftware.com/viaduct.aspx
This took about a month from start to finish - too long!
Graham Plowman
