All track is ordered, wood to build the baseboard is being purchased tomorrow
This is the layout in AnyRail, size is 10'x3:
I'll endeavour to update here regularly!
Wood paint is something else I should buy tomorrowMountain wrote: ↑Fri May 09, 2025 3:51 pm Losely place track where it should go. Draw roughly around track areas. Paint track areas a ballast colour. Paint other scenic areas greenish or brownish colours. The basic idea is when adding ballast and scenery, any gaps in either that are missed will look a more natural colour.
People said to me beware straight ovals as it will get boring with only the end curves. Personally, I think it depends If you want to run trains quite quickly then straights are worthy but if you want to run them slowly, maybe some curved sections instead of arrow straights may be a consideration?rreckless wrote: ↑Fri May 09, 2025 3:21 pm I'm finally ready to begin building my 1st layout since I was a kid and my first ever in N gauge. Erinburgh, named for my daughter, is a fictional city in the north of England. Layout will be a continuous loop modern day setting. Control will be DCC, points will eventually be automated using DCC also, but this will come a little down the line.
Once I've loosely laid the track, I may look at adding some variety on the straights. Excessively long straights is certainly something I'm wary of.centenary wrote: ↑Fri May 09, 2025 5:26 pmPeople said to me beware straight ovals as it will get boring with only the end curves. Personally, I think it depends If you want to run trains quite quickly then straights are worthy but if you want to run them slowly, maybe some curved sections instead of arrow straights may be a consideration?rreckless wrote: ↑Fri May 09, 2025 3:21 pm I'm finally ready to begin building my 1st layout since I was a kid and my first ever in N gauge. Erinburgh, named for my daughter, is a fictional city in the north of England. Layout will be a continuous loop modern day setting. Control will be DCC, points will eventually be automated using DCC also, but this will come a little down the line.
One thing I did neglect to do at the design stage was plan my wiring and where my control panel would be sited. Now, it's a bit of a head scratching exercise of figuring out where I want what! Good luck with automating all those points!
100% buy paint, build the board, drill holes for cables in cross sections etc (not point or dropper holes though, just any large holes), drill and sand any hand holds you want - and seriously think about how the sections can be moved - even if its all getting bolted firmly never to move again..rreckless wrote: ↑Fri May 09, 2025 4:02 pmWood paint is something else I should buy tomorrowMountain wrote: ↑Fri May 09, 2025 3:51 pm Losely place track where it should go. Draw roughly around track areas. Paint track areas a ballast colour. Paint other scenic areas greenish or brownish colours. The basic idea is when adding ballast and scenery, any gaps in either that are missed will look a more natural colour.![]()
the only comment I'd make on what looks like a fun layout is the reversing loop track is quite short and may cause you a few issues - if you are not going for block stuff I'd be tempted to make the entire central bit, including the stadium station and quarry yard the reversing section, so long as you only drive in or out but not through with anything longer than the points top or bottom you will be finerreckless wrote: ↑Fri May 09, 2025 7:58 pmOnce I've loosely laid the track, I may look at adding some variety on the straights. Excessively long straights is certainly something I'm wary of.centenary wrote: ↑Fri May 09, 2025 5:26 pmPeople said to me beware straight ovals as it will get boring with only the end curves. Personally, I think it depends If you want to run trains quite quickly then straights are worthy but if you want to run them slowly, maybe some curved sections instead of arrow straights may be a consideration?rreckless wrote: ↑Fri May 09, 2025 3:21 pm I'm finally ready to begin building my 1st layout since I was a kid and my first ever in N gauge. Erinburgh, named for my daughter, is a fictional city in the north of England. Layout will be a continuous loop modern day setting. Control will be DCC, points will eventually be automated using DCC also, but this will come a little down the line.
In terms of wiring, I'll be planning that once I've built the baseboard. As Mountain mentioned above, I'm going to trace out the track on the board and then base my wiring off that.
