Leopard's Bufferstop Challenge
Vote and comment on New Railway Modellers Competitions.
aleopardstail
Post by aleopardstail »
Off to a slow start, but at least off to a start.
"da plan"
12" square plywood offcut, the track bit is a double track mainline section, on a raised bed about 2" raised (using stripwood offcut front and back on another plywood deck). the rear of this gets a siding, with a bufferstop obviously, this would normally be lower but here will be slightly higher. all the track will be on XPS (offcuts) but not cork (don't have and spare), rear probably just two layers of XPS.
I can spare a yard of track for this
the back will be a higher retaining wall as thats a nice visual break and explains the verticality of the thing. the front being a lower retaining wall down to a road area. no buildings as I want to use this as a photography backdrop, also hence won't have sides, ends will be capped with something, probabyl greyboard and painted.
ok, progress..
the base has been found, the trackbed offcut found and cut to size, stripwood offcut cut to size and each bit of plywood has a bit of stripwood glued to it. to be glued together tomorrow and ideally the trackbed and maybe even the track added.
its also going to be a scenic test section, nothing here will be powered though (did ponder a red lamp on the buffer stop, probably not really needed, a 1930's one won't really be visible in daylight)
Phred
Re: Leopard's Bufferstop Challenge
Post by Phred »
The crowd erupts as aleopardstail joins the fray! :D
Post by Dad-1 »
The ideal 'Test' projects.
I like just rough outlines as to what is going to appear ...... Plenty of time ?
aleopardstail
Dad-1 wrote: Sat Nov 23, 2024 8:13 pm The ideal 'Test' projects.
hopefully can get the actual track part of it done pretty quickly, don't think anything needs buying to get track down, or for that matter using the remains of dingleberry's supplies getting the track painted and ballasted either. heck even have point rodding I could do with experimenting with as well.
walls etc will take a bit longer but I think, at least hope, its doable
aleopardstail
Phred wrote: Sat Nov 23, 2024 8:13 pm The crowd erupts as aleopardstail joins the fray! :D
should be worth a video or two at the very least :)
aleopardstail
board made, XPS down, and painted
needs to dry and can then add the track
Phred
Post by Phred »
Absolutely!
aleopardstail
while downstairs earlier, I finished the track
its an imaginative layout scheme as you can see
next up..
aim is the mounts in place, likely one or two runs, thinking along the rear of the mainline (so its away from the drop at the front for maintenance staff). the rods come later but mounts in place then can start with a bit of paint
Interesting!
Post by Dad-1 »
Ooooh, I used some of that when I could see !!
It certainly adds another dimension to trackwork.
Phred
Post by Phred »
A very different diorama. Such a variety of styles and themes in this competition. :)
aleopardstail
Bit of progress, video out at some point, made a start with the retaining wall. 12" long, 40mm high to the base of the trackbed - will need (and will get) a short wall above that to be added later.
render of the central section, turns out making brick patterns isn't all that hard to do
Post by Dad-1 »
Phew, I'm not the only one who's been stalled.
Good to see progress.
aleopardstail
Dad-1 wrote: Wed Dec 18, 2024 7:30 pm Phew, I'm not the only one who's been stalled.
yes was getting worried for a bit here, amazingly they printed in a usable way, bit uneven along the bottom edge, well a bit of pavement and some general grot will hide that. should get them primed tomorrow
Post by Dad-1 »
"General Grot" sounds a suitable name for Lofty, his record of usually very
dirty run down scenes.
Pristine always looks wrong, unless it's a new car on delivery !!
Geoff T
