My piece of ply is quite small and an odd shape. I have a Teutonic brain that doesn't like
the odd shape so I shall square it up with an outer frame. Because I like an easy life I shall
also add 4 small pieces of wood underneath as feet, to help in picking it up !!
The only certain thing so far is adding a Bufferstop. I have had this laying in my shed for years,
I think the packaging proves that.
That will need some aging, but how to use. I'm moving towards a run-down gravel extraction works
where I might be able to introduce water. Time pressure a problem in making some worn out
equipment, a rusty shed no problem ????? Still flexible as it should be possible to make in about
4 weeks once the ideas fill out.
Geoff t.
