Welcome to New Railway Modellers Forum. Read the Introduction and Terms and conditions of New Railway Modellers model railway forum. Introduce yourself to the members in this section.
blackcloudrail
Post by blackcloudrail »
Hi, it was suggested in a conversation over on the NGRM forum that I might like to join here to share my penny-pinching modelling exploits. My prime interest is On30, not NG7, following a freelance Latin American railway.
Railcars, coaches, wagons and some locos are kitbashed using cheap second hand toys (as above) and modified die cast models.
This is my third attempt at getting reacquainted with BB code. Here's a layout tour link, which was what was flummoxing me with the code in the two previous attempts.
The preview shows it working this time so I'll hit "Submit" before I mess it up again. :roll:
Re: Hi
You made it onto the site! :D
The site is on some sort of automatic inactivity timer as one posts, so if one types for too long, it logs you out as it assumes you are inactive.
To get round this on longer posts, post a shorter post, and then ammend it to make it longer.
What make is the turntable or did you make it yourself?
blackcloudrail
Re: Hi
I did indeed, thanks for the signposting. :D
They are scratch built or kitbashed. (above, left to right) Cuarto de Pulgada, Derrotado and San Fernadez make extensive use of coffee stirrers. Antequera uses Peco bridge girders and Grande's turntable has girders from an ancient Airfix kit. They're manually operated and pivoted using lids from various sized jars, selected so they nest one within the other.
Ex-Pat
Re: Hi
Post by Ex-Pat »
Welcome to the Forum - what a fascinating layout - Grande reminds me of Belturbet in County Cavan where there was also a Standard Gauge/Narrow Gauge Interchange. And mention of Perejil casts me back to walking the disused Parsley Hay to Ashbourne line way back probably in the 90's.
In addition to Mountain's advice you can of course save a draft - although I prefer to compose long posts in Word and then just paste the final draft.
Re: Hi
Post by Dad-1 »
Welcome aboard blackcloudrail,
Always refreshing to see some different aspects & scenes.
glencairn
Re: Hi
Post by glencairn »
Welcome on board, blackcloudrail. A good crew here.
Re: Hi
blackcloudrail wrote: Tue Nov 12, 2024 10:13 am I did indeed, thanks for the signposting. :D
Very nice. What about the wiring?
Phred
Re: Hi
Post by Phred »
Now that's my kind of modelling! Nothing gives me greater (modelling) pleasure than creating something on the cheap. Welcome. :D
GaryMorris
Re: Hi
Post by GaryMorris »
Hello blackcloudrail, welcome. I've just joined myself, you have some great photo's.
Gary
blackcloudrail
Re: Hi
Thanks for the welcome messages. :D
Dead simple, San Fernandez is on a DPDT on/off/on switch, replicating this on the others is on the to do list but until then they are connected via two-pin plugs. These can be reversed when the deck is swivelled or left unplugged to isolate the turntable. The wires are threaded through holes in the pivots and have sufficient play in them to absorb several turns in the same direction but I try to alternate between clockwise and anti clockwise so they don't get too twisted.
The loco shed tracks at Grande are wired via on/off switches in a fairly conventional manner but the shed at Cuarto has its connections via a crocodile clip on a lead that can be attached to either track using a couple of pins at the baseboard edge. Similar crocodile clip/wander lead connections are used to power/isolate the main and loop tracks in the station at San Fernandez.
The wiring at Cuarto used to allow for two trains in the station but I connected something wrongly when I moved the terminus to do away with two duck-unders at doorways. The sidings can still be switched but the loop and main are a single section. TBPH this is not an issue because the timetable never calls for two trains at once.
There are three controllers (Grande, San Fernandez and Cuarto/Derrotado) so, in theory, there could be three operators on the layout but it is usually run single handedly apart from monthly operating sessions when a friend visits to play with the trains.
Re: Hi
You have given me an idea. Those plugs and sockets used with headphones could act like both an electrical connection and as a central pivot for a turntable?
I love your simple crocodile clip idea. I bought a small pair of those several years ago and I have not used them yet. one can use specific length wires so they can't reach nails that they are not supposed to reach in theory. Makes for a very good way to provide electrical switching "One the cheap".
Other ways can be invented from paperclip wire etc... Possibilities!
When I was into 00, I had Peco points with Peco point solenoids and I wired these via a mimic diagram and used the probe and stud method and it was so much quicker and easier and cheaper than using any other method! These days though I want "Hands on" manual control via point levers.
aleopardstail
Re: Hi
Post by aleopardstail »
Mountain wrote: Thu Nov 14, 2024 10:39 am You have given me an idea. Those plugs and sockets used with headphones could act like both an electrical connection and as a central pivot for a turntable?
those connectors can be used, the quarter inch ones are better as thy are more robust, use a panel mount socket for the layout. takes care mounting such. not used such for model turntables but have used them for other things that need to rotate - note you can get three and four pole versions if needed
