Update 12/2 to ask about tunnels - Track ballast and static grass question and tunnel portals
So i have a trackplan that i am happy with (only took 8 months but it will work for me). So now my mind turns to ballasting track and static grass. So i have two questions.
1. What size ballast would people recommend for OO gauge track? I have a feeling it would be medium but wanted to check. Will be using woodland scenics trackbed if that makes a difference.
2. I understand about using different size static grass, seems some 2mm, 4mm and 6mm seems the way to go. But how do people mix colours, and do you adjust colour and size for lets say a green field and area around a tunnel entrance for instance?
Any views much appreciated.
Re: Track ballast and static grass question
Ballast varies according to circumstances, but for the UK post 1970 or so the stones would be in the 37 to 50 mm range, with a lower minimum size of 10 to 30mm previously. On Woodland Scenics US site they give the specs of their ballast - the medium grade matches exactly the BR/Railtrack spec in O gauge! This would imply a smaller size for 00, whatever is below 'medium'. However, what the eye sees may require some flexibility - dead scale does not necessarily translate well visually, so it's a bit of a case beauty being in the eye of the beholder so to speak. I.e. do whatever looks good to you.barney121e wrote:
The best thing is to look at photos of the real thing to see how it works and then mix and match. Personally (O gauge) I do a coat of 2mm (two or three shades) and then add areas of 4mm, 6mm (or 7) to get texture (if that's the word). If it goes wrong don't be afraid to scrape it off and have another go. This bit of the hobby is 3d art really so there's no hard and fast rules, the only way is to try it and see.barney121e wrote: 2. I understand about using different size static grass, seems some 2mm, 4mm and 6mm seems the way to go. But how do people mix colours, and do you adjust colour and size for lets say a green field and area around a tunnel entrance for instance?
Hi barney 121e,
Ballast size ?
I have usually used Woodland Scenics Medium on my '00' although fine is actually a more appropriate size as Richard08 says.
There is a practical reason, That is it's easier to lay and less likely to fall through any small openings around wire feed holes.
Secondly being that bit coarser it's easier to keep out of point workings, even allowing single grains to be collected on the
pointed end of a dampened kebab stick.
Grass, I look more at blending colours than length. Nature has almost zero colour consistency, I tend to try and colour shade
to fit certain landscape variations like damp hollows, or thin soils on a ridge that dries out. Never have a real plan, just work
as I fancy, all artistic like !!
Ballast size ?
- luckymucklebackit
For me, definitely fine ballast. What is described as 00 ballast is for me looks too large. Mind you I model 1960s and I think ballast size was smaller back then.
Thanks all, all helpful stuff.
For a little narrow gauge layout that I've started, using N gauge track, I bought a bag of 'washed river sand' from Bunnings, the Australian equivalent of Homebase. I sifted it through three different sized sieves until I found a grain size that looked right. Cheap as chips, except that chips are not all that cheap these days.
Re: Track ballast and static grass question and tunnel portals
Hi guys
A quick question. As i am using setrack i am finding it difficult to find a tunnel portal, and guess i might have same issue with a bridge. I do have a scalecast mould that i have cut and put a small bit in to widen the portal, and looks ok, but does anyone have suggestions on other portals and bridges? Looking at 125mm internal measurement minimum.
Wills (Peco). Modelscene and quite a lot more. Google will help - watch out for HO ones being sold as OO though.barney121e wrote:Hi guys
I'm having the same problem as my tunnel mouths will be on set track curves and the longer rolling stock hangs out over the track width.barney121e wrote:i am finding it difficult to find a tunnel porta
I think I need a vertical walled tunnel rather than a curved wall tunnel.???
Have looked at those but the width isnt enough. The only one i have find is a downloadable one by Smart Models.Richard08 wrote:Wills (Peco). Modelscene and quite a lot more. Google will help - watch out for HO ones being sold as OO though.barney121e wrote:Hi guys
Possibly. The Smart Models one should work, i also have a scalecast mould which i have added a little bit in the middle, will post a picture of it below. Im halfway thru painting to see what it looks like.End2end wrote:I'm having the same problem as my tunnel mouths will be on set track curves and the longer rolling stock hangs out over the track width.barney121e wrote:i am finding it difficult to find a tunnel porta![]()
Re: Update 12/2 to ask about tunnels - Track ballast and static grass question and tunnel portals
Will it be on straight or curved track barney?
Could you possibly take a picture of it 'in situ' please just to give me a rough idea?
Also, if you've made the tunnel mouth out of 2 casts, I wonder if you could cut off the bottom stone either side of the unwanted cast and stick them to the bottom of the tunnel mouth just to give it that little bit more height with 2 'foot stones' either side instead of one as the curves might impede clearance?
Hi @End2endEnd2end wrote:Will it be on straight or curved track barney?
Photos below. I have put it on a bend as this is where it will go on my layout. Seems room all round. The first photo is of the smartmodels one, just the tunnel opening on a bit of A4 just to get the idea. Hope that helps.
Thanks barney. That does help.
As far as ballast goes, nearly all suppliers produce it overscale. I find that using OO scale ballast for O gauge and N gauge ballast for OO is a pretty good choice.
I wrote an article on ballast scale here: https://modelrailways.online/pages/vu/BallastSize
And how to lay it: https://modelrailways.online/pages/vu/BallastingTrack
Building tunnel mouths on a curve here: https://modelrailways.online/pages/vu/M ... unnelMouth
