I found these T shaped connectors which would suit many of my needs.
Does anyone know if they are available in the U.K.?
And perhaps if they have a specific name?
Although looking like something WAGO would make they don't seem to be manufactured by them.
https://www.ebay.co.uk/itm/394128249299 ... R-6SvP3qYA
'T' shaped connectors. Available in the U.K. ?
Re: 'T' shaped connectors. Available in the U.K. ?
They would be great for the display board demo circuits we used to create, but tucked away in a joint box any three way connector would do. They remind me of my "Water Analogy" bridge rectifier that I built from windscreen washer tubing and valves, and a couple of large syringes with their plungers glued back to back to generate an alternating pressure source. Wonderful fun messing about with tubing water and ping pong balls to show that the flow went one way..
Also here in different colours and cheaper with qty buy. Use the drop downs to see all options.
https://www.ebay.co.uk/itm/384771106115 ... 101224.m-1
Thanks RAF96.
Not knowing what they are called, I didn't find these in my searches.
Yes, I know a company that provides T-connectors services. But a problem is that they are providing T-connectors service in the USA. The company name is tinktube. I think so you should contact their team maybe they have another store in the UK. I hope it will be helpful for you.
Work hard
Not the same connector Andrew.
Check my initial link for them.
I did manage to buy some in the end.
