Football pitch
SOOTYBRUM
Football pitch
Post by SOOTYBRUM »
Building a N gauge Thomas the Tank layout in a suitcase for my grandson and I want to add a football pitch. Does any one know what size it should be in N gauge? Thks
Re: Football pitch
The smallest you should go for true scale is 600mm long, 300mm wide, although a minimum of 420mm wide is preferred, and that's to the dead ball line, you need some space around that for the Linesmen to run in, Managers and Coaches to shout, scream and gesticulate, and the reserve coming on to warm up...
Re: Football pitch
Then again our nearby primary school five a side pitch would come out at 180mm long, 120mm wide.
SOOTYBRUM
Re: Football pitch
Post by SOOTYBRUM »
Many thks.. will go with the 5 a side pitch
