O Gauge Wire Mesh Fencing
Hi, does anyone know of a supplier of O gauge mesh/security fencing, the kind you get round a fuel depot. Or the bits to make such (the Woodland Scenics stuff is way to 'clunky').
Re: O Gauge Wire Mesh Fencing
I got some woven mesh which was too small for 4mm "gabions" might be passable as 7mm mesh. Remind me next week if I haven't come back on it. I'll need to search for the invoice. They had multiple sizes of woven metal mesh. My 4mm mesh for fencing is "bridal dressmaker's lace. Right size holes but a real b' to paint.
John W
aka bufferstop.
John W
aka bufferstop.
I have a theory. If you spray paint it where you have a non stick sheet of something above the fence, and you spray from below, the spray will hit the underside of the fence and also the spray will bounce off the non stick material and land on the other side of the fence, so one could (If it works) spray both sides in one go? It is just a thought. It might not work.Bufferstop wrote:I got some woven mesh which was too small for 4mm "gabions" might be passable as 7mm mesh. Remind me next week if I haven't come back on it. I'll need to search for the invoice. They had multiple sizes of woven metal mesh. My 4mm mesh for fencing is "bridal dressmaker's lace. Right size holes but a real b' to paint.
John W
aka bufferstop.
I saw a lovely 09 layout which had some lovely barb wire fencing which had been home made.It was very effective.
Thanks for the replies. Someone, LCUT?, does the concrete posts with the angled bit on the top, so guitar strings would do for the support wires and barbed wire is available for the angled strands at the top - the real problem is the mesh. I got some exquisite stuff from HobbyHolidays for walk-way gratings, but the lack of photo's on their site make picking the right one somewhat problematic (I guessed for the grating mesh and got lucky!) This is the sort of thing I want to recreate
Would some sort of muslim cloth do as repinted no one will know that it is not metal.
Barbe wire I saw was ordinary thin wire that someone had handmade individual barbs onto it.
- Ironduke
That would be "muslin".Mountain wrote:Would some sort of muslim cloth do
"tulle" ribbon might work?
https://www.ribtex.com.au/product/6013- ... lack-1roll
don't know where you'd look in UK.
Have you tried here ? If they don't have it they may well know where to find it. https://www.scalelink.co.ukRichard08 wrote:Hi, does anyone know of a supplier of O gauge mesh/security fencing, the kind you get round a fuel depot. Or the bits to make such (the Woodland Scenics stuff is way to 'clunky').
Colin James....
Thanks again for the replies - food for thought & search
The material suggestion is interesting - I need to look at net curtains perhaps! And a plough through the Scalelink site... Medical gauze has also been suggested.
Cheers!
Cheers!
Barbs?Mountain wrote:Barbe wire I saw was ordinary thin wire that someone had handmade individual barbs onto it.
In 1:36 scale?
That's barbaric!
Ironduke wrote:That would be "muslin".Mountain wrote:Would some sort of muslim cloth do
Ah. So it does not come from the Middle East?
Haha.ChrisGreaves wrote:Barbs?Mountain wrote:Barbe wire I saw was ordinary thin wire that someone had handmade individual barbs onto it.
In 1:36 scale?
That's barbaric!
Invoice proving illusive, so resorted to Google. Take a look here
The sample from Amazon looks promising. Looking at the prototype thing above, the most important thing is that it's as near invisible as anything. The holes are probably the right size, its the wire joining them together that's a bit thick
Richard, you are in luck! I have just yesterday completed the two wooden chimney covers, a task which was due over twelve months ago:- Here is one of the covers, upside down, with its layer of carpet scrap around its edges. The hole in the centre uses a scrap of electrical cable for a weight suspended inside the chimney to hold the cover in place. I have left a trimming of carpet in the centre. Here is a close-up; it seems to me that the silvery-grey looks as if it doesn't need painting; just glue it to uprights and your oil-depot is well protected. Limited stocks are available until next year, when Bernard gets back to tipping truckloads of grass clippings at my place. Each truckload comes with a wide variety of debris, all of it useful. Please do NOT confuse the sample shown in the second image with what you usually see when you rip out old office carpet. There is a coarse-grain suitable only for higher scales (but I don't know what comes after "O". "1" and "2" I suppose). The coarse base holds a finer base (Image 2) which then holds a pile of carpet fibre.Richard08 wrote:Hi, does anyone know of a supplier of O gauge mesh/security fencing, the kind you get round a fuel depot. Or the bits to make such (the Woodland Scenics stuff is way to 'clunky').
FREE postage to anywhere in the world, if you can't lay your hands on someone else laying carpet!
The bottom photo looks promising - getting all the carpet off might be a tad time consuming. Goes off to lift corners of carpets 'just for a look'...
