DTM30 Sensor Wiring
Stour
DTM30 Sensor Wiring
Post by Stour »
Hi Everyone I am new to this forum and would appreciate some help.
I have a DCC Layout using Digitrax and CML / Sig-naTrak boards.
The storage yard is divided into 48 blocks wired through 3 BDL168.
The control panel has DTM30 boards used to control points and routes.
The BDL168 show the correct blocks as indicated by the LT5 Tester LEDs and displays the same on LocoAnalyse. My problem is wiring or programming the DTM30 cells to display the correct LEDs.
Can anyone advise on which ribbon cable goes to which pin number to display correctly and on programming the DTM30.
Many Thanks
Kevin
BromsMods
Re: DTM30 Sensor Wiring
Post by BromsMods »
I assume you have read the manual!
If not you need to download it and look at sections 4 and 5.
Stour
Post by Stour »
Yes and I new the man that wrote it! Doesn't solve the problem unfortunately.
