Heljan Class 47......Not running
Hello,
I have a Heljan Class 47, which looks pretty unused and newish. It will not run on my oo gauge set up, but when I removed the body from the chassis I was faced with an electronic motherboard, which has left me confused. I have no experience with Heljan, so can someone tell me if I am able to use this loco on my present lay out or is there a "switch" which requires regulating like some of the new Marklin 1 guage, to put it into DC mode.
Any help you can give would be appreciated, the unit is Mint condition so I do not think the loco is faulty, its probrably just me, suffering lockdown Syndrome. Serial number on the motherboard is 85436007.
Hopefully I can attach a photo, but think I need an alternate "Ology" to even use NRM's attachment facility.
regards,
Bobby
regards,
Bobby
- Attachments
- IMG_5252.jpg (10.5 KiB) Viewed 3026 times
Re: Heljan Class 47......Not running
There's no switches, it's a a regular 12V DC mechanism, with a decoder socket for DCC fitting.
Is the blanking plug fitted in the decoder socket?
Do you have flying leads from your 12V DC controller that you can connect directly to the motor leads to test if the motor runs when power is applied?
Often it is these blanking plugs which can cause issues if they don't quite make an elwetrical connection. The idea of them is to make the model easy to convert to DCC as one takes out the blanking plug from the socket, and replaces it with the decoder plug part. However, some of these blanking plugs have caused issues on occasions.
It might not be that which is faulty. There are quite a few things that can make a model act up.
DC is quite a lot easier to work out what is happening. The idea is to check if the current is passing through the wheels and to the motor. Some faults are a short somewhere. Other faults are that the current is not getting through, and there are then the mechanical faults like something has ceased, or something has jammed or is rubbing.
Back to basics to start with. Ensure wheels, pickup strips and the backs of wheels are clean. Also the track. Next stop is to check the connections to the pcb on top. You'll find that they are all held by the wire going through a hole in the pcb and then a small black plastic keeper is pushed over the top to secure it. The one's for the motor (prime suspects in your case) are either side midway along the pcb. There are two at each end from the track, these are alongside the light connectors, you can see where they are heading down to the lower part of each bogie. It's less likely to be these as this loco picks up current from both ends. I solder these connections and do away with the plastic keepers. This ensures you always have a good connection. Check these things and let us know how you get on.
A quick edit: As Bigmet says, check that the motor isn't dead by disconnecting those two wires midway along the pcb and use you controller or a 9v battery to see if it runs. All this assumes you're on DC supply.
One other suggestion that you could try in conjunction with the above suggestions: Lift the circuit board out gently (it is only held in by the rubber wedges along each side) and see if you can manually turn the motor and drive shafts. If anything has seized, you'll feel it there first. That will also allow you to check those brush wires more easily or connect to them with the battery or controller wires.
Heljan's basic construction is simple and robust, so it is easy to get at most things to check them.
Thank you for your very informative replies. As I have said Heljan's are a completly new breed for me, so please bare with me.
The good news is that I have released the pcb from the chassis, checked, checked the main red/black power wires to the motor with my controller and all work fine, including drive shafts, and wheels. I am sorry to admit I do not know which item on the pcb is the blanking plug. There are no wires actually going through the pcb just 3 connecting plugs each end of the pcb each taking the red/black wiring from the wheels to the motor.Checking the wheels via the controller, power is not being transmitted to the motor, whilst all the pickup brushes are connecting, wheels are clean and there is nothing intruding the drive wheel pattern.
OK, reading all your comments I feel it may well be the blanking plug ?? Your help is certainly appreciated,
Best regards,
Bobby
Best regards,
Bobby
- Attachments
- IMG_5256.jpg (10.56 KiB) Viewed 2988 times
- IMG_5258.jpg (9.07 KiB) Viewed 2988 times
- IMG_5257.jpg (9.83 KiB) Viewed 2988 times
The DCC socket blanking plug is in place, it's the pale brown item with two L shaped solder blobs on, an 8 pin type.
Good news, the model is a runner when the motor gets power.
My suspicion would be that someone swapped around the plug connectors on the board ends and got it wrong. Track the pick up wires to the plugs that connect to the board sockets each end. It should connect to 'L and R' - so long since I looked at a Heljan 47 that I don't recall if they are labelled. Whatever, a little trial and error with the pick up wire plugs into the available sockets should get you there.
As Bignet has said, the blanking plug is there. It's the pale brown rectangle sticking out in the lower photo. It doesn't look like it is fully pushed home, so you could try giving it a good firm press with a finger.
A long shot.
My Heljan class 33 wouldn't work - dead.
However the previous time I'd had it out it worked fine - it was a very hot day and in a museum
where it ran continuously for many hours.
The answer was that a white grease used by Heljan had melted and left a thick enough film
over the wheel backs for the wiper pickups to just slide over it, fully insulated !!
A thorough clean and de-greasing of the wheel backs and pickups solved it.
Hello again,
Well......all of your process of elimination and input has worked, and I have a very nice running Class 47. Having pressed all the 6 end and top connectors firmly into the pcb, she showed signs of life. With a couple of slow runs round the track she is now fully operational.
Thanks again for all your input, without which I could not have cured the situation,
Very best regards to all, and keep safe,
Bobby
Bobby
File that away in 'simple fixes', because if you buy s/h you will find all sorts of minor trouble like this. (You can save real money this way: lots of 'non-runners', unreliable, 'slow running' and 'spares and repairs' all performing beautifully on the layout after relatively small adjustments, wires reconnected, solidified grease cleaned out, parts removed and loose in the box restored, and look at that it works properly!)
As usual my memory let me down. I should have opened mine up to double check on the connections. Not little bits of plastic holding wires in... that's Bachmann. Sorry.
Hi Im having the same problem with a 47 not running .Ive checked power to the motor ,through the circuit board ,and the pickups ,all working OK however when I put power to the wheels nothing .Ive not tried using IPA on them yet ,but at a loss as to how its not picking up .Any answers please .
Two things to check first on the loco.
Is there any oily deposit on the wheel backs, as mentioned above? If so wipe clean.
Are the wheels a brown colour? Heljan started out with brass wheels in their locos, and the 47 was their launch product in OO. If the model has been out of use for a while the wheel surface oxidises and becomes less conductive, and that affects both the tyre contact with the rail and the wiper contact on the wheelback. A little running polishes off the oxide. Put the loco on track and 'jump start it' with flying leads to the motor, that usually does enough to begin the process, then run the loco normally on track power for a half hour or so.
And of course, check there is actually power on track if you haven't done so already...
HTH, and welcome to this site too!
Just a quick warning. Do not put power direct to the motor if the loco has a DCC decoder fitted as it could potentially fry the decoder. Only do this to locos that are DC only.
DC is easier in this way as one can simply check the motor in situ, but for DCC one has to isolate the motor supply from the decoder to test the motor from a DC supply.
