Overlapping sleepers
Brian2
Post by Brian2 »
Playing around with the new O gauge this problem arose. How do users cut and space out these overlapping sleepers/chairs etc?
Imageuntitled (1 of 1)-8 by Brian Tompkins, on Flickr
Peco O gauge code 124 Bullhead.
GeraldH
Re: Overlapping sleepers
Post by GeraldH »
I normally try to move the sleepers on the plain/flexi track so that they interlace. If necessary cut the webbing under the track, so that you can slightly alter the spacing. The sleepers could be cut with a razor saw.
Post by Bufferstop »
The long sleepers should really be used until normal sleepers would clear each other. I'd settle for straightening the last one of the point base, and modifying the first two on the bit of straight track. Then trimming those that overlap so that they fit each other.
