Triangle blue pullman
Can anyone tell me the correct silver paint colour for the roof. Mine is a 251 model with yellow front nose. Thanks
Re: Triangle blue pullman
As far as I know there's only one silver paint. The only thing I'd say is that like other "metal" colours if you are using a tinlet of the stuff you have to stir it longer than solid colours so it mixes well. Get a tin and paint it on a piece of plasticard and put it alongside the existing roof to check the match.
Thanks for the reply. I'll try it.
Sorry, but I disagree with you, b308: there are quite a few different silvers around. I found this when experimenting with the finish on my London Transport A Stock train, where I really needed a very flat, almost grey-white aluminium finish. A spray can of car paint (a Peugot silver) looked nice but not accurate, and was much more metallic in effect than Humbrol's standard silver #11 (which, I should add, tarnishes and wears badly with handling in my experience).
I am also experimenting with a Tamiya silver paint for some other jobs, in preference to the Humbrol paints. Humbrol also have a different silver labelled as 'Aluminium' (can't remember the number off-hand).
For Frankie2, I would suggest trying a few different silver paints to see which either matches the original Triang colour or satisfies you as to the finished effect if you intend to paint all of the roofs to match.
Maybe true, I've only ever seen one type of silver in the shops and that's what I've bought, but once they were out in the British weather it becomes academic, especially with diesel fumes being plastered all over them... Even in model form the colour changes over time... So unless the model is ex works and not to be run then does it really matter?
On the subject of silver paint Citadel miniatures have a variety of different silver acrylic paints. They also produce other "metal" colours.
From memory I used Tamiya "aluminium" in a spray can when I refurbished my old Blue Pullman set. The finish looked factory.
- Dalerailman
I used pound shop silver spray cans before though usually only round in the run up to xmas. Wilko did have a good range too
Roof colours are never "fixed" whether they are aluminium or white lead paint over tarred felt. Last time I saw the "British Orient Express" set of Pullmans you could work out the order of their refurbishment by looking at the roof colours. When seen from the top of the stairs at Snow Hill the roofs of the Blue Pullmans were mostly to be seen in that unique colour "British Rail Filth" as they were cleaned with hoses and brushes working along the sides. The situation still exists as coach washing plants only do the sides, exhaust pipes and OLE equipment rule out the possibility of a top brush.
Bufferstop wrote: unique colour "British Rail Filth"
I can see it now in a Humbrol (other makes as well) tin.
Graduated from Soran University with First Class Degree with Honours in Computer Science
Absolutely agree with the principle here. Unless you are touching up some quite small areas, not only are ‘metallic’ paints extremely difficult to apply consistently over large areas but they are also difficult to match up with existing paint. Spraying is the best solution by a country mile and, with care given to masking up, it is extremely easy to achieve a factory finish.GWR_fan wrote:From memory I used Tamiya "aluminium" in a spray can when I refurbished my old Blue Pullman set. The finish looked factory.
Tony
