Dapol semaphore signals
I recently bought an OO gauge GWR home signal. It worked perfectly on a dedicated 16V ac supply. I installed it on my layout and connected it to the 16V ac supply that also powers the point solenoids. After the first operation of a point solenoid the signal died. I contacted Dapol and their comeback was to ask if I was using a CDU (which I don't) and that the signal was not repairable. Obviously a power spike when the point operated destroyed the electronics in the signal. There was no mention in the paperwork that you shouldn't connect up this way. The moral is - don't do what I did and use a dedicated supply for the signal although I presume if you use a DCC module you won't have these problems. Having dismantled the base, it looks to be possible to modify the signal to be cable-operated, so all may not be lost.
Re: Dapol semaphore signals
There is a thread as long as your arm about these signals on Rmweb, and I think much of it is about assorted faults. Don't know if any of it will help.
22 pages of discussion on these on RMWeb - http://www.rmweb.co.uk/community/index. ... ls-review/
I would definitely consider the signal faulty and return it to where you bought it from for either a refund or replacement.
Robert Smith
Thanks for the feedback - I'm new to this and unfortunately I wasn't aware of RMWeb.
- flying scotsman123
Lucky you...chrismartin wrote:Thanks for the feedback - I'm new to this and unfortunately I wasn't aware of RMWeb.
Yeah, don't dare criticise anyone or anything if you join. Don't get in to any debates and don't pass anything but grovelling comments or you'll find yourself being censored.
Or, indeed, do anything a different way to the majority, as it will be WRONG!
Except Hornby. Hornby bashing is ok. In fact, criticising quite a lot of people is ok, usually ones who aren't there to have a right of reply. But I'll stop now.Peterm wrote:Yeah, don't dare criticise anyone or anything if you join.
Don't worry about the signal, we've all been there. See if you can get a refund and try again, if not, you appear to have the proper* modeller's attitude of "Damn it I'll make it work".
(*As in the proper attitude for a modeller - not the attitude of a 'proper modeller'. Let's not start the debate about 'proper modellers' here, I'll leave that to the other place as well).
I'd be far more enthusiastic about the Dapol signals if they required different conditions to set on or off. Press-on,press-off control is a menace anywhere
I thought the Dapol Semaphore signals need a momentary switch? (On)-Off type. Or is that what you mean BS?
So you press and release the non locking push to make Push Button for the signal to drive to the Off (Cleared) position, then press and release again on the same PB to return the signal to its On position. Or can be worked by a Hornby R044 Black lever or Peco PL26 lever with both the levers output connections linked together on the PL26.
No not my best description, just a single pulse switches it both ways. Like the standby button on most TV remotes, doesn't seem to default to danger at power on either.
I experienced problems with some of my Dapol signals failing quickly. I contacted Gaugemaster and they recommended using a 12V DC supply. I changed the signal power to their GMC-WM4 plug in transformer and have not experienced any problems for some time, but I don't get the backlit spectacles.
I am awaiting the Dapol GWR gantry signal. I tried to contact Dapol about it but got no reply. A friend suggested contacting the model railway press, which I did. I got a reply from Key Publishing that said they had contacted Dapol who advised "The bracket signals are now in tooling and we expect to have product out to market later this year or early next year.”
I wish I could remember what Adrian of Rail Room Electronics said about them.
I believe it was ONLY use 12V DC, but as I've had a couple fail I'm not buying any more.
If the spectacle light does not come on you have the polarity wrong on the red and black wires.
I have just received a newsletter from Hatton's. They have given reference numbers for three motorised GWR junction bracket signals. One is a two arm left hand junction bracket and the others are left and right hand single brackets. I hope a two arm right hand junction bracket will be produced. Can anyone confirm this?
