hi, has anyone used scale lighting with a select? and have you had any problems of shorting out?
just wanted to see if anyone has had any problems and what you did to overcome them
amarjot
Hidaleks04 wrote:HORNBY skalelighting![]()
amarjot
Actually it is 16 volts ac.Flashbang wrote:You could use a 12 volt PSU such as the Hornby C990 which will allow 0.8Amp (800ma)
Your 100% correct, it is 16 volt ac at 0.8Amp.hobby boy wrote:Actually it is 16 volts ac.Flashbang wrote:You could use a 12 volt PSU such as the Hornby C990 which will allow 0.8Amp (800ma)
Hidaleks04 wrote:You see, I need to buy 2 transformers which came with the select
but cannot find any. ( one for lights, one for points) does anyone
know where I can get these. And maximum trains running at one time is 3, so I thought
maybe I could get the 4a one to power trains and lightng, meanwhile using the 1a one to power my
analogue point switch system. Wil the 4a be able to power lights and trains?
