Road Surfaces
Road Surfaces
Hi,
For some time I've been wondering what the best road surface for my layout would be. It's a modern layout, and I am unsure whether to use paint, metcalfe card, or something else, Any suggestions?
thanks,
Alex
thanks,
Alex
Re: Road Surfaces
Take a look at some real world road surfaces (or even some photos). I wanted a well worn look to match the road over a bridge. I ended up using a part worn finishing sheet from my orbital sander. Colour was a good match, and it had the right degree of randomness.
Re: Road Surfaces
What about Wet & Dry paper; it has a rough texture, is grey, durable and to make it look weathered all you have to do is het a sharpie and draw random lines on it.
Re: Road Surfaces
Thanks very much, but does anyone know how the javis tarmac roll looks like - is it realistic, or just a rough job?
thanks,
Alex
thanks,
Alex
- SouthernBoy
Re: Road Surfaces
I've been looking at road surfaces a lot recently - and the majority of them aren't actually 'textured'kiwitram wrote:What about Wet & Dry paper; it has a rough texture, is grey, durable and to make it look weathered all you have to do is het a sharpie and draw random lines on it.
I know where you're coming from kiwitram - because they look textured - but it's an illusion. Most roads are stones mixed into tar and then leveled (well, slightly cambered so the rain runs to the drains)... so it's that mix which gives them a textured 'look'.
And now you make me think of it I've got the perfect solution.
Take ballast, mix it with plaster (which has a proportion of back paint in it so it's mid to dark grey), make your road, then sand it back to a smooth, cambered finish. Hey-presto! perfect road surface
Damn, I wish I'd thought of this a few weeks back as I've just finished my main road and now it won't satisfy me having thought of a better way to do it! Than again, I know how to do it better next time.
Obvious other solutions are the numerous 'out-of-the-box' pre-printed road surfaces in card or foam or plastic. Or just lay any old card card and paint it grey.
Re: Road Surfaces
what about the scalescenes roads??? that way you can have as many as you want.
Andrew
Andrew
I have this engine like the picture
GWR 0-6-0 Pannier tank
Check out Andrew's layout Hookstoke Junction UPDATED! Should do more work as it's now the Easter Holidays
After the holdiays are over, my layout won't get updated much Age = 15
Re: Road Surfaces
The joints you would get puts me off SS... Unless you have any tips?!hobby boy wrote:what about the scalescenes roads??? that way you can have as many as you want.
Re: Road Surfaces
,what about the scalescenes roads??? that way you can have as many as you want.
I've already got some of them thanks, but I'm not sure whether its my laser printer, but they seem to be too shiny, and don't look very authentic, but thanks anyway
Re: Road Surfaces
An australian firm makes a spreadable roadbase called Simply Roadbase.
You trowel it on with a palette knife to 1mm thick.
Dont know if its sold outside Oz, check their website http://www.simplyglues.com.au/
cheers, mistered
cheers, mistered
- Si_Donal
Re: Road Surfaces
I'd definately go with the fine grade wet and dry paper, painted with cheap domestic wall paint. I like a shade called moonstone. It can be weathered with pencil lead ground up and rubbed along the route of the road with a wet finger.
Si
Leisure Time = those moments between the lists of jobs that a wife gives you to do.
Visit my layout thread at: http://www.newrailwaymodellers.co.uk/Fo ... 22&t=24781
Re: Road Surfaces
Sandpaper, emery cloth, and wet & dry all just look like exactly what they are and are not a good representation of road surfaces. IMO you can't beat cardboard; the plain grey type with a little surface relief (and with packing underneath down the middle to form a camber) carefully painted with various acrylic greys and weathered with a 2B pencil to replicate tyre and exhaust staines.
G.
G.
Re: Road Surfaces
Do you have a photo of the finished result? I am trying to work out the best way of doing a little used country lane for my layout, and the method above sounds like it might have the best simple/effective balance.Grahame wrote:Sandpaper, emery cloth, and wet & dry all just look like exactly what they are and are not a good representation of road surfaces. IMO you can't beat cardboard; the plain grey type with a little surface relief (and with packing underneath down the middle to form a camber) carefully painted with various acrylic greys and weathered with a 2B pencil to replicate tyre and exhaust staines.
G.
J
Re: Road Surfaces
Julia wrote:Do you have a photo of the finished result? I am trying to work out the best way of doing a little used country lane for my layout, and the method above sounds like it might have the best simple/effective balance. J
Hmm, it's not exactly a country lane
G.
Re: Road Surfaces
But surely you also have joints using sandpaper?Flakmunky wrote:The joints you would get puts me off SS... Unless you have any tips?!hobby boy wrote:what about the scalescenes roads??? that way you can have as many as you want.
"I'd like to die quietly in my sleep like my grandfather, rather than screaming in terror like his passengers"
Re: Road Surfaces
Ah! but even in 00 a sheet of sandpaper will more than cover the length of a UK road, that you will find before coming to a patched pothole, a reinstatement scar, a repaired failed surface joint or a bit of official surface graffiti intended to inform the poor road user of something that is quite obvious!ngresley wrote:But surely you also have joints using sandpaper?
