Re: BARGAINS!
Re: BARGAINS!
Post by TimberSurf »
luckymucklebackit
Re: BARGAINS!
Post by luckymucklebackit »
Obsidian87 wrote:Hi
Dont know if this applys everywhere or if everyone uses UHU glue but the UHU all purpose glue 60mm tubes i found in the st helens home bargains for 99p a tube (with the not quite precise nozzel but they not hard to change) just in case anyone needs any.
Been buying mine out the pound shop for a few years.
D605Eagle
Re: BARGAINS!
Post by D605Eagle »
Naughty Rails are having a Bachmann clear out. Some cracking bargains on there. I'm £305 lighter now for 4 new tender locos. Can't say no to that!
clicky
Re: BARGAINS!
Don't the rules state that the wonderful booty obtained at bargain rates has to be listed?
(I won't be tempted because it's the Oxford N7 in BR black that suits me.)
D605Eagle
Re: BARGAINS!
Post by D605Eagle »
Does it?
Anyway I got an LNER liveried O4 and lined LNER K3, an LMS liveried 3F and 4F. Postage counted for £7.50 which was a bit of a supprise. I expected it to be a flat £4 like Hattons, but theirs goes up when the quantity does.
Mike Parkes
Re: BARGAINS!
Post by Mike Parkes »
Not seen much mention if any of Topcashback here - works on the web site referral system the same as adverts and you get a percentage back of your purchase from any web site, subject to certain limitations such as a maximum on the monies refunded and use of discount codes on the web site, linked through Topcashback (I presume they keep a slice as there are no catches involved). Model railway wise seems pretty limited but you do normally get 1.01% back on ebay purchases (sometimes at weekends its higher) and when you decide its time for a payout you can get a further credit on various e-gift cards (i.e. my accumulated £8.98 turned into a £9.52 M&S e-gift card) If you join by this link https://www.topcashback.co.uk/ref/mike_p before 10am next Monday you should receive a £5 virtual prepaid Mastercard when you have accumulated £10
Hymirl
Re: BARGAINS!
Post by Hymirl »
https://www.modelrailwaysdirect.co.uk
Doing a sale on locos in 00 and N gauge. Decent price on 0-4-0 pecket...
sishades
Re: BARGAINS!
Post by sishades »
Just bought the new j36....curse you train sales/
Re: BARGAINS!
Just been to B&M, they have artist acrylic paint tubes (big ones) in a wide range of colours for £1.49!
BuffyMcBuffer
Re: BARGAINS!
Post by BuffyMcBuffer »
TimberSurf wrote:Just been to B&M, they have artist acrylic paint tubes (big ones) in a wide range of colours for £1.49!
Are they any good? I see paint tubes in shops and think hmmm would they be any good to use?? But then think they can’t be....
What would you use those for then??
Re: BARGAINS!
Mix 'n' match every shade under the sun! Absolutely everything! I am even using in my airbrush (with some reasonable results) but mostly for major scenery like......
BuffyMcBuffer
Re: BARGAINS!
TimberSurf wrote:Mix 'n' match every shade under the sun! Absolutely everything! I am even using in my airbrush (with some reasonable results) but mostly for major scenery like......Portal Arch 7.jpg
Hmm they do look good!
Might have to have a nose when I go in next
BuffyMcBuffer
Re: BARGAINS!
Popped into Poundland (again) as little man has to make a Easter bonnet hat..... but the up side was the misses saw a bag of this and asked if it would be any good for the layout
Looks rubbish tbh but I will give it a go. Any shade of green helps
glencairn
Re: BARGAINS!
Post by glencairn »
BuffyMcBuffer wrote:Popped into Poundland (again) as little man has to make a Easter bonnet hat..... but the up side was the misses saw a bag of this and asked if it would be any good for the layout
I haven't seen it (yet), but as you say 'Any shade of green helps'.
Mix it in with other greens Very tiny dots of yellows, blues and even less whites and even less red. Then hide it in brown earth colour powders/tea until around 50% is covered.
BuffyMcBuffer
Re: BARGAINS!
Will try that thanks,
I have been drinking peppermint tea recently. I save the bags to dry out instead of throwing them in the bin
I finished one box already and have quiet a bit of green foliage saved up from it
Just opened the bag to see what the contents is like and it looks alright, I would say useful for woodland floor area and probably bushes if stuck to scouring pads (which I also picked a pack of 10 and cut to strips still got 4 pads to cut up yet)
Here are some close ups of the moss
