Peco N gauge st-7 crossing problem! wont fit!
xstoka
Post by xstoka »
Hi there,
Can anyone help me cause im abit lost, im laying out a n gauge set track plan that is in the peco settrack track plans booklet and the crossing st7 does not seem to work. the attached image is not possible as the st7 crossing can not be used to get track that runs alongside each other straight, it runs at an angle, has anyone got any advice?
poliss
Re: Peco N gauge st-7 crossing problem! wont fit!
Post by poliss »
I had the same problem. It's because the angle of the crossing is 25 degrees, while the turnout's angle is 22.5 degrees. None of the track plans with the ST-7 crossing work.
Tosh
Post by Tosh »
Substitute the ST2 going from ST5 to ST7 with a bit of flexi track :wink:
Beer,making ugly women look beautiful for thousands of years.....
xstoka
Post by xstoka »
cheers for the replys, now i know its not possible ill find a way around with flexitrack or something!!
Post by Bufferstop »
I know it's only a sketch, viewed on a screen but even the join between the ST-7 and the following ST-12 doesn't appear to work.
Zunnan
Post by Zunnan »
The difference may be 2.5 degrees but that plan can be made to work. Have a look at the layout Smallman28 produced, it's a lovely example of how to make a track plan book based layout.
Under Construction N Gauge dog bone.
Canon Street. N Gauge
The Workbench.
phonebook
Post by phonebook »
i know i have a bee in my bonnet about the st7, but it is SUPPOSED to be setrack, and therefore work in the way peco say it should, and from their own publications, they believe it does!!!! but it doesnt, they should change the geometry immediately.
Flakmunky
Post by Flakmunky »
Bufferstop wrote:I know it's only a sketch, viewed on a screen but even the join between the ST-7 and the following ST-12 doesn't appear to work.
I think that is an optical illusion!
Bufferstop wrote:...but it is SUPPOSED to be setrack, and therefore work in the way peco say it should, and from their own publications, they believe it does!!!! but it doesnt, they should change the geometry immediately.
I agree completely. I couldn't understand why they designed it with the geometry they did. Hornby's track is a good example of how it should work.
Having said that, the Code 55 stuff does work very well indeed. I just swapped out a small point for a double slip and didn't have to cut any of the adjoining track...
