Eppustadt.... And so it begins again
- Essex2Visuvesi
Well I have finally found time to start building my layout here in finland
I had intended to do a Finnish outline layout but sadly there is almost no RTR stock in The VR livery, (Roco do one Loco) so I decided to go for German post war steam.
I have been collecting up a few things that will feature on the layout... the centrepoint being an operational cablecar system (when Finnish customs let me have it)
The starter set
The trackplan
and baseboards part 1
I am intending to use the fibre underlay from laminate flooring ontop of my baseboards... looks like this
Has anyone else tried using this before?
More track and buildings ordered today so watch this space
The starter set
The trackplan
Last edited by Essex2Visuvesi on Fri Apr 24, 2009 7:25 am, edited 1 time in total.
Proud member of the OAM
Re: New Home New Layout
Nice to have a bit of variaty, and in 'n' gauge . Cant wait and the car system! Do they make it in 00/HO ?
Jake
Modelling Jakey's Junction!....
See here for my plan:
http://www.newrailwaymodellers.co.uk/Fo ... 44&t=19546
Part of NRM'S officail freight masters
dudes club
dudes club
- Thunderbird
Good luck with "the layout in Ikea", bet that the plan changes.
good luck with it, glad to see that you got moved and settled ok.
What's happening on the garden layout plan? or are you waiting for the bears/wolves/yeti's to leave before you venture out?
Manager of the Famous under-achieving Lawton Rovers (NRM xperteleven div2)
Plans are now afoot for the 2nd relocation and resumtion for my N gauge layout Lawton Road..
- Essex2Visuvesi
Yes they do several different ones for H0 6 to be exacttrains! wrote:Nice to have a bit of variaty, and in 'n' gauge . Cant wait and the car system! Do they make it in 00/HO ?
http://www.brawa.de/en/Products/H0/Funiculars.html
I'm guesssing they cost a lot. I may modify one to look british then use one.
Jake
dudes club
dudes club
- Essex2Visuvesi
most likely it will change but heres hoping .Thunderbird wrote:Good luck with "the layout in Ikea", bet that the plan changes.
Its -12c outside at the moment so not much happening on the garden layout at the moment. I think that will be more a project for the summer
- Essex2Visuvesi
the baseboards have been built now
but Im having second thoughts about the trackplan
Any suggestions for changes to the trackplan?
- Essex2Visuvesi
Re: New Home New Layout Eppustadt
I have made a few minor changes to the trackplan and a name for the station "EppuStadt"
the pics and layout were made with a program called Wintrack. http://www.wintrack.de Its rather expensive to buy but I found the CDS in a second hand shop for a 5 euros its not the latest version but its a whole lot of fun to play with
Plan view
Im still a novice with the software but this is what can be acheived when playing with the additiona scenic packs:-
And an Artists Impression of the countryside part of they layout
Hope you like the Pics
Coming Soon
Plan view
Coming Soon
- Essex2Visuvesi
A quick Update on the Garden layout:-Essex2Visuvesi wrote:most likely it will change but heres hoping .Thunderbird wrote:Good luck with "the layout in Ikea", bet that the plan changes.
Now the snow has melted I can see we have a major problem with making a garden layout
As the snow melts we end up with huuuuuge dips in the ground which slowly return to shape some of which can be up to 18" deep. In order to keep the track safe from damage I think I would need some fairly hefty and deep footings.
I have some more Ideas but I need to do some more research before continuing.
Re: Eppustadt.... And so it begins again
I used this on my last attempt. To my mind it worked well and was cheap. BUT you either need to glue it to the baseboard or use lots of trackpins..to go straight through the sleepers, the foam into the board.Essex2Visuvesi wrote:I am intending to use the fibre underlay from laminate flooring ontop of my baseboards... looks like this
One bit of advice would be to drill the sleepers dont be tempted to push the pins through as they will bend into the foam.
- Essex2Visuvesi
Thanks for the info I have Glued the boards downusing a 70/30 mix of PVA and water, spread on liberally and then weighted down with a selection of heavy household objects
More updates to follow today
Essex2Visuvesi wrote:the baseboards have been built now
For realism, why not make your straight sections a bit less straight. Especially the long ones on the outside of the 'L'. A bit of gentle sweeping curve would look nice, and break up that parallel geometric look.
Otherwise, I like the trackplan.
My N Gauge Quarry Layout - Trecarreg http://www.newrailwaymodellers.co.uk/Fo ... hp?t=14555
Money Talks.....It mostly says "Goodbye!"
- Essex2Visuvesi
Im still working on the long rear sections, i think these will be hidden by a mountains and a gradient with maybe a "pop out" bridge. I havent as yet worked out how to create the mountains and tunnels on the trackplan software.engineer dave wrote:Essex2Visuvesi wrote:the baseboards have been built now
Ill update later with improved plans
- lozstlouis
Are you building it in a sauna? Nice.Essex2Visuvesi wrote: and baseboards part 1
- Essex2Visuvesi
Nope its in the main entrance hall way, the sauna is through the door to the right of the first pic
