Scourcing G scale ballast?
I run an indoor Gauge 3 layout which at 13.5mm to a foot is about the same as G scale, but I am having difficulty finding suitable ballast for the tracks, say approx 3 to 4 mm, any ideas would be welcome.
Re: Scourcing G scale ballast?
http://www.woodlandscenics.com/clipper wrote:I run an indoor Gauge 3 layout which at 13.5mm to a foot is about the same as G scale, but I am having difficulty finding suitable ballast for the tracks, say approx 3 to 4 mm, any ideas would be welcome.
-> Roadbed/Trackbed -> Ballast
has a chart that may be useful?
Richard
I have become.......comfortably numb
I have used horticultural grit or aquarium grit .they both 'grip' nicely and are perfect scale.
mikey
mikey
Why not try grit salt?
Pete92
___________________________________________________
Currently: Texturing Base board
Next Step: Adding foliage
Pete92
used small shingle (Wickes)and a small amount of concrete mix to bond it.
Hi Clipper
I realise this is a really old post but if you are still looking for a very realistic and lightweight "G" scale ballast TREEMENDUS produce just what you are looking for. It is cork based and pale grey in colour.
why not just use 00 gauge stuff?? I mean go look at a railway in realife, and you can see there are 5-6 individual stones of ballast between each sleeper. Well if you use normal 00 gauge stuff on 00 gauge track, you get 1-2 stones between each sleeper. So maybe if you used medium or coarse 00 gauge stuff, it'd look to scale.
Cliff Barker can provide ballast in bulk to go with his range of Gauge 3 (and Gauge 1) track. See website http://www.cliffbarker.talktalk.net/index.html. Ballast is listed in the Gauge 1 section near the bottom of the page.
I suspect using umpteen bags of the size usually available for 'OO' would be simply unaffordable, given the surface area occupied by Gauge 3 in comparison.
