Southern Garage Layout (old pics up to page 27 added)
Post by mumbles »
Hi!
Welcome to a New Mumbles thread!
The Attic is too cold and having ummed and ahhed about a rebuild and insulation job up there i decided to take operations into the garage.. because dismatling the loft would mean having no operational 00 layout.. and i'd was thinking that would be the harder of the 2 alternatives.
So the garage today as it stands after 2 dump runs looks like this
http://i62.photobucket.com/albums/h87/mumbles274/g1.jpg
and a bit further back
http://i62.photobucket.com/albums/h87/mumbles274/g2.jpg
an idea of how much junk there is still to clear, note the electrics.. they don;t work, this place needs a rewire [When you coming down Martin? :D ]]
http://i62.photobucket.com/albums/h87/mumbles274/g3.jpg
and to remind you of what i have stored in here and hope to continue onwards with
http://i62.photobucket.com/albums/h87/mumbles274/g4.jpg
http://i62.photobucket.com/albums/h87/mumbles274/g5.jpg
this is the picture that is driving me on at the moment, with a vision that at some point i will be running trains through this piece of scenery and sitting in a nice, warm, secure, train room [none of which it is yet!]
http://i62.photobucket.com/albums/h87/mumbles274/g6.jpg
immediate jobs are to;
*clear the rest of the junk and spiders
*line with some sort of insulation and damp proof sheeting
*board walls and ceiling
*wiring, power and lights
*flooring, old bit of lino probably
then, and only then will it be time to start modulating!
any tips/suggestions about these plans, please fire away, i have a working plan in the grey matter but if you can think of any thing that would help, or i should avoid, fire away
and i look forward to a fun 2008.. it will be interesting to look back in a years time and see where this started
as an idea this was where my attic was exactly a year ago
and where it was when i last took a pic in sept 07
Michael
PTmodeller
Post by PTmodeller »
Good luck!
boyofbears
Post by boyofbears »
have you got a track plan for this layout? and wwhats the size?
good luck with tha future :D
my imaginery friend thinks u have problems.......wait........
my layout http://www.newrailwaymodellers.co.uk/Fo ... 22&t=17368 new!!!
Chuffer Chuff
Post by Chuffer Chuff »
I agree with PT, I'm sure you will have a lot of fun!! :D
Post by mumbles »
this is the track plan as it stands, although i think i have the dimensions wrong of the baseboards
also i think this is not how it would end up, very much a plan in progress
the bottom half is the scenic part, i would like the curves to be more sweeping too and tot try to get away from everything being parallel to the edges
michael
ollyg16
Post by ollyg16 »
What? No Mumbles "trade mark" inverted figure of eight?
(Hic?)
:shock:
PS Good luck with the layout.
Hope you find a lost Picasso in amongst the junk.
K9-70
Post by K9-70 »
mumbles wrote;
* 1.) clear the rest of the junk and spiders
* 2.) line with some sort of insulation and damp proof sheeting
* 3.) board walls and ceiling
* 4.) wiring, power and lights
* 5.) flooring, old bit of lino probably
* 1.) Clear all the junk, (place on ebay)? and allow yourself a clear working space.
* 2.) insulate with fiberglass insulation or cut polystyrene sheet and place between the rafters. then cover with polythene or fibre board/plasterboard.
* 3.) It's unlikely that your garage has a cavity wall, most likely single skin, so I would drill and fix 2x1 timber battens on the walls, placed at 400mm center's, fill in between them with fibreglass insulation, cover with polythene and either fibre board/plasterboard.
* 4.) You'll need to get a qualified spark to do this work.
* 5.) Lino's too cold, foam underlay and cheap carpet ?
Hope these ideas are of some use to you
K9-70
The Rides the "REASON" the "DESTINATION" is only an "EXCUSE" :-).
Post by m.levin »
Are you going Dc or Dcc?
Post by mumbles »
K9-70 wrote: * 2.) insulate with fiberglass insulation or cut polystyrene sheet and place between the rafters. then cover with polythene or fibre board/plasterboard.
K9-70
cheers, all good and appreciated
2/3 > thanks, sounds like a good idea, poly or FG is prob better than that foil stuff i had thought of using
4> i know, thats a bit of a pain
5> thing is lino can be swept, and i won;t be barefoot in there so i'm hoping with a bit of underlay and lino i should be ok, may well consider carpet though as i have some offcuts in the loft
tina von lightmeister wrote:Are you going Dc or Dcc?
dunno, dcc would be preferred i think, would have to see what funds permit, might ask the missus to start saving for my birthday in july!
michael
Post by m.levin »
When you listern to the NSE 108 with sound you will be convinced
Post by Lofty »
Hi Michael,
After you mentioned moving into the garage a couple of months ago I thought long and hard about doing the same.
I have decided to crack on at altitude at the moment, but I expect to have my next layout (thinking 2 – 3 years) in the garage.
I look forward to following your progress. I will be releasing my ‘new ideas’ on the January 1st. Looking at the state of your garage at the moment I will probably be a couple of man-hours in front of you to start with (unless you have a really good couple of days construction).
Am I correct in spying a corrugated roof, if so what is it made off? I suspect you may well suffer from condensation drips, how are you planning to overcome this?
Post by Lofty »
Am I correct in assuming you only have the one door, which is the standard ‘car entrance’.
When I was looking into doing a garage project I saw this as a major headache and would have built a stud wall behind it with a more normal size access rather than open up a whole end wall to the elements.
Bushey Troughs
Post by Bushey Troughs »
lofty wrote:Am I correct in spying a corrugated roof, if so what is it made off? I suspect you may well suffer from condensation drips, how are you planning to overcome this?
Looks like cement/ASBESTOS........Happy New Year........ :P
COLIN.
Post by mumbles »
it is corrugated, i think it might be asbestos :oops:
i plan to board over it and make sure i don;t drill into it, i can;t say i've ever noticed any condensation in there but i can;t say its my favourite place to hang!
michael
Post by Lofty »
It sounds like it is the same as mine.
I had an indoor bike trainer in mine a couple of years ago. Half an hour of stationary cycling used to produce a condensation patch above me.
I also have noted that a stiff breeze from the back of the garage when raining has forced a bit of water up between the overlapping panels.
