00 scale lorries
Jim S-W
Re: 00 scale lorries
Post by Jim S-W »
Hi all
I have yet to upgrade the chassis on these but when I do, I'll take piccies. The big and quick fix is to pull the wheels out so that they are in the right place.
The RM tractors now have drivers, windows and a spot of weathering. I have re-positioned the windbreaker on the Cargo. I didn't realise I had run out of Roadtrain mirrors though!
Also OMWB as a couple of quickies
On the left, Ford Consul and on the right, Cortina both from Oxford Diecast. Usual treatment is to spay them with matt varnish, turn the tyres down a bit, subtle weathering and fit occupants. (the Cortina is destined to be parked) I ground off the spotlights on the consul and both will be re-registed.
Jim S-W
Post by Jim S-W »
Hi All
Drawing a close to my ford Cargo project with this ADL version
Needs a spot of weathering on the wheels then its done.
This brings my fleet of Cargo's to 7 which is enough for now
A good que for someone to bring a good RTP one out I think!
thebritfarmer
Post by thebritfarmer »
They are all excellent Jim. The Sunblest is my favourite one though.
All Aboooooard !!
Jim S-W
Post by Jim S-W »
Sometimes the stuff in the toybox needs a bit of a sympathic eye to see any hope for it. I present you..
The Matchbox Dodge Command and below after some hacking to the cab and marrying to a base toys chassis and modified box body
The picture below shows where the destruction was required!
Jim S-W
Post by Jim S-W »
Hi All
Been tidying up a few loose ends of stuff thats been OMWB for a long time. So long that I forgot all about this one!
Another ford cargo combined out of a Corgi Cab, base toys chassis, unknown wheels and a body made using the Hornby Curtain sided van sides.
Jim S-W
Post by Jim S-W »
Hi All
A few more lorries for you
Another Dodge commando from a modified matchbox cab and a Base toys Leyland FG
A Base toys Roadtrain converted to a Freighter - below is how the cab was chopped up
This was re-assembled then the back cut off to loose the small window. a spot of filler and some sanding and its done.
Essex2Visuvesi
Post by Essex2Visuvesi »
Does the 'S' in your screen name stand for 'Surgeon'?
Proud member of the OAM
code3modeller
Post by code3modeller »
Loving the Leyland conversion!
Ive strated a flickr account with some of my Cargos on there if anyone is looking for ideas?
http://www.flickr.com/photos/tilcon_vehicles/
Jim S-W
Post by Jim S-W »
Cool thanks
Do you have links to photos o the original vehicles? Especially the British gas freight rover? Also I notice the rendering of the White arrow express logo is not quite right. The lower case 'e's should be at an odd angle and the alignment of the upper case lettering is very different.
See http://www.flickr.com/photos/james-powe ... hotostream
Hth
Essex2Visuvesi
One to add to your livery collection
code3modeller
There already is a Roadline truck on there but its not a bedford its a cargo....but im working on it lol
code3modeller
Hi Jim,
It was just drawn by me using a standard high roof pic and photos of British Gas Vehicles.
Phil
Jim S-W wrote:Cool thanks
Hth
code3modeller
Hi Jim,
Tried to change the White Arrow vehicle but photos on the net are few and far between.......
Phil
Jim S-W
Post by Jim S-W »
Hi all
Started work on the BW Models kit for the Volvo FL6
This one is going to be a challenge! For more see http://www.p4newstreet.com/category/workbench
Pete
Post by Pete »
HI Jim
Is there glazing with this kit, or will you have to improvise/not bother?
I'm looking forward to seeing how you rectify the problems, and I'm sure it'll look great once you finish.
Pete
It's the nature of evolution
The dinosaurs went to Hell
