Great rescue! Ive spent many an hour getting a twist out of RC sailplane wings and it's a real pain in the proverbial to get everything straight again!aleopardstail wrote: ↑Fri Jan 17, 2025 12:49 pm bit of paint added, roof needs going over again to smooth it out, bodywork is done bar panel lining etc, underframe black details to sort out
coming out nicely, colour isn't quite right, not red enough but its close and I think weathering will make it look light faded
do the twist again..
Re: do the twist again..
finally gotten the glazing in and the underframe painted, couplers turned up.... and don't really fit, too short, thinking now 3d printing a NEM pocket and seeing what I can find to fit into it
glazed and underframe painted, roof attached (badly, fit is rubbish)
hopefully video up tomorrow about this one
What couplers ?
I like to know when things haven't worked out quite right.
I always use Peco dove-tail mountings - They always need hand made 'fitting'
with various amounts sanded off the two ridges to get spot-on height.
Lengthwise I usually have the open end of a NEM pocket directly over the
bufferbeam/headstocks, perhaps closer to the outer end for longer buffered
stock. Then either Bachmann short narrow tension-lock, or again if extra
length needed the Bachmann long version.
Then a simple snap out to put Kadees in. I normally use #18's, but for extra
length have used both #19 & #20.
Anyway looking good. I never know exactly where to place these long wagons
in passenger trains. I seem to think I've seen them directly behind the locomotive
and other times added on the back as an afterthought !! Then perhaps some
were parcels trains & I didn't notice ??
Bachman "short" couplers, the kits have mounting pegs for them, the dovetail ones would be a lot better. thinking currently is get something like that and 3d print a mount for them.Dad-1 wrote: ↑Sun Jan 19, 2025 9:48 am What couplers ?
as for where they go, my thinking is the back, reasoning being upon a trains arrival it can be quickly removed to another platform for unloading while the train is sorted out for departure. then when the time comes for the van to depart its shunted into the departure road ahead of time, then the coaches backed down onto it coupled and off it goes so the loading & unloading don't impact the actual trains too much
I would convert to KD, if not for the price of the things which is frankly ridiculous
Looks good to me. I doubt anyone would notice when it's on the layout.aleopardstail wrote:
I was reluctant when I saw the price (and that was years ago) but I have to say the KD couplers have performed flawlessly. Still haven't fitted them to everything, just using a match truck where necessary.aleopardstail
nah the roof fit matters, that was needed to hold the body square and its just not doing it, its about 0.5mm too short for the body and the shape of its underside doesn't match the ends of the body very well. if it was a gaming model it would be getting two part filler but not really practical here as would have to respray a lot after.Phred wrote: ↑Sun Jan 19, 2025 10:25 pmLooks good to me. I doubt anyone would notice when it's on the layout.aleopardstail wrote:
I did wonder on KD for locomotives and ends of some wagons, the layout will see a lot of block formations, e.g. rakes of four coaches that would only need them at the ends, I may still get some and try them, can't use under board magnets as the station area won't have space under so would be the visible ones anyway. one for the future
