NRM Article - DCC for beginners (Part 4 now up)
Articles which have been added to the main site
pete12345
Re: DCC for beginners (Part 3 now up)
Post by pete12345 »
Sorry, I don't have any pictures of my own installations (I tend to get carried away and forget to take any pictures :P ) but there are some excellent pictorial guides on Steve Jones' website http://www.electricnose.co.uk/dcc/dccdecoders.html
He seems to have fitted a decoder to every basic type of loco, and you can get some inspiration from there.
Pete
EDIT: Post 1111 :lol:
santene
Post by santene »
that websites amazing :D thanks
leviathan1949
Post by leviathan1949 »
An excellent thread Pete.
As easilyconfused mentioned earlier for anybody that wants to TALK DCC with the UKTS Team, pop along to any of the exhibitions where we take the DCC Workshop and we will gladly answer any questions. We are at the Leytonstone Exhibition this Saturday.(17th May).
Without imposing on Petes precious time, for those wanting instructions for fitting decoders in to specific locos then Google for your particular loco and in most cases you will find a site somewhere that has done it before and documented it.
Dapol have a few on their own site under the DCC menu option.
Bromsgrove Models also has a large number of links to various sites explaining individual installations.
There are NO hard and fast rules for decoder installations, with manufacturers changing designs very often, the instructions can only be serious guidelines at best.
As a simple example one guy I know has a ZIMO system and wants to fit a ZIMO MX64H into his loco. He also wants a Loksound sound chip in there as well. Given that the Loksound has traction control and full light functions AS WELL as the sound, you might ask why does he want the ZIMO chip as well. Answer because he prefers the traction control that the ZIMO has but wants the sound capability of the Loksound.
And Yes, it can be done, if there is physically room for the two decoders in the loco.
pete12345
Re: DCC for beginners (Part 4 now up)
Post by pete12345 »
Part 4: Decoder programming
As requested, here’s a how-to on programming decoder CVs
The first thing we need to install, before thinking about programming the decoder, is the programming track. This is a low-powered section of track we use when configuring the decoder. In the event of an incorrect decoder installation, this also does not have enough power to destroy the decoder.
Most command stations will have a separate output for the programming track. For Lenz, the convention is terminals P and Q. The simplest way is to connect these to a spare piece of track, and you’re away. However, it avoids having to pick up the loco if you have a siding which can be switched between the main track or the programming output, the wiring for which is shown below.
This way, you can change the loco’s settings by just driving on to the siding and throwing the switch.
Ok, now we get to the programming itself. I’ll be referring to the procedures with my Lenz Compact, but the principle is exactly the same on all systems. Use your controller’s handbook in conjunction with these instructions.
There are two types of decoder CVs: simple ones which take a decimal value, such as the decoder address, maximum speed etc, and complex ones which use a binary system to turn settings on or off. First let’s cover the simple ones. The one everyone will need to set is the loco address; CV1.
Right, with the loco positioned on the programming track, we enter program mode.
· On my controller, programming mode is accessed through the menu.
· Select CV1 and confirm.
· Confirm again to read back the current setting (with a new loco, the address should read back as ‘3’
· Change the address with the +/- keys and confirm again to set the address.
· The display should now read the new setting.
That’s it! Wasn’t that simple? Most of the basic CVs can be programmed in this way. Examples are acceleration delay, braking delay, maximum speed, starting voltage. Even using these, you can set up most of the characteristics of each loco.
A quick note on the Lenz Compact:
The instruction manual for the Compact will tell you that you can only write five CVs, which are accessed through ‘register’s. However, at some point the circuit board was changed to allow all CVs to be read and written. The manual was never updated. To access the other CVs, you first have to read back any of the basic registers. Then, after scrolling past R8, the display should change to C09. You can then alter any CV you want.
Now we move onto the complex CVs. These are for things like setting up lighting effects on the function outputs, and adjusting the decoder’s basic settings.
If you look at the decoder instructions, you will come across something like this:
To the beginner, this looks a bit daunting. How do we work out this lot?!
Well, each ‘bit’ can either be on or off. When it is off, it stands for nothing. When it is on, it stands for a number. What number? Each bit is worth twice the amount of the previous one. So when ‘on’ bit one is worth 1, bit 2=2, bit 3=4, bit 4=8, bit 5=16, bit 6=32 etc. So each decimal number corresponds to a unique combination of ‘on’s and ‘off’s.
Still following this? Don’t worry, I’ll show you an example. Take a look at the table for CV29. Suppose you wanted to set up the decoder with normal direction, 28/128 speed steps, operation on DC, standard speed curve, and with CV1 as the address. This means that bit 2 and 3 are on, while the others are off. This means the number we need to set is 2+4=6. This is the default setting for most decoders.
If you wanted to use a custom speed-curve (set up using other CVs) we need to switch on bit 5. This adds 16 to the number, making it 22.
You can apply this process backwards to work out the current settings. Suppose you had a reading of 5 on CV29. The only way to get this number is 1+4, so bit 1 and bit 3 are on.
This process seems a little complicated just reading it, but it’s a lot easier once you get the hang of it, and is far easier to do than it looks- have a go. The hard part is converting binary to decimal. You can actually use your computer’s calculator to do this if you can’t do it mentally.
One final tip: if you completely screw up the programming of your decoder, entering a certain value (depending on the decoder) in CV8 will reset the decoder to factory settings.
sishades
Post by sishades »
33 in CV8
This varies according to the chip being used. TCS and Bachman use 2 and 8 in CV 8 to perform a rest.
pete12345
Post by pete12345 »
Article edited: thanks for pointing that one out
Pete
tinman
Re: NRM Article - DCC for beginners (Part 4 now up)
Post by tinman »
Very useful article thanks, especially as I'll soon be starting to lay & wire track !
Is there anything special that needs to be done with diamond crossings and double slips ? (both peco code 75 electrofrog in my case)
Martin.
If at first you don't succeed - hide all evidence that you tried...
I didn't do it, nobody saw me do it, you can't prove a thing ! (Bart Simpson)
BROADTRAIN1979
Post by BROADTRAIN1979 »
Hi ,
As my layout is 4ft 7" by 3ft and is 'n' gauge, (it is dcc) my feed wires are here and there, but for better loco command, is it good to have feeds, every section of track? My track is clean but my 37 does stall, here and there .Is that because ,i havent enough feeds? and also ,is 00 scale dcc different to 'n' scale dcc? as my dads, oo scale trains, run almost to zero ,over uneven track, where mine dont.I imagined all dcc scales were the same .
Youll never find a 501 like mine.
hiffano
Post by hiffano »
hey there, any chance of
either
a - compiling this into one post/or downloadable PDF,
or
b - would you mind if i compiled this into one pdf, and happily share it with the rest of the forum.
jimp
Post by jimp »
Why not just copy each each part that you want and paste in eg Word?
Jim P
centenary
Post by centenary »
Charlie at Chadwick MR has just released a good vid on You Tube regarding cvs.
https://youtu.be/XNODDraVe5g
Katler
Post by Katler »
CSGOEmpire UK, running since 2016 under Curacao-based Moonrail Ltd, is a trusted skin‑gambling site offering classic CS:GO betting modes like roulette, coinflip, case battles and match betting through a sleek, fast, fully mobile‑optimized interface that supports skins, crypto and fiat deposits/withdrawals, featuring provably fair systems, two-factor authentication, optional KYC for larger withdrawals, 24/7 live chat and email support, a zero‑fee peer-to-peer skin marketplace https://csgoempire.co.uk/ , daily free cases, referral rewards and loyalty tiers—though users should be aware of occasional regional restrictions and mixed feedback on withdrawal delays or support wait times
OLD Forex trader
best forex signals from me
https://toptradingsignals.net/goldsignals
