Hi all I am trying to fit cab lights to my hornby Class 66 that has 21 pin decoder socket I cant work out what pin is what and were I need to wire the I need to find out what pin AUX1 is and were do I connect the negative side of the lights to ground or to pin 16 common ? any advice would be great as I cant get a reply from Illuminated models
Mark
Fitting Cab Lights
Re: Fitting Cab Lights
HM7000 pin outs but the decoder fits a standard 21-pin socket. Hardware function outputs (HFOs) are switched negatives in conjunction with common positive.
Hi Raf96
Thanks for the chart its really helpful however I am still unsure which way around to wire the cab light I may be over thinking things so
Pin16 is V+ Common
and Pin 15 is Aux 1
but do I wire the
LED Positive to Pin 15 Aux 1
LED Negative to pin 16 Decoder Positive Common. I have tried this and it didn't work
or
LED Positive to pin 16 decoder common
LED Negative to Pin 15 decoder Aux 1
LED positive to Pin 15 Aux one
Led Negative to Pin 20 decoder Ground
Any more advice would be very grateful
Mark
Pin16 is V+ Common
and Pin 15 is Aux 1
but do I wire the
or
Mark
If you want Aux 1 to operate the cab lights wire the LED with suitable series resistor - LED Anode (positive) to 16 and Cathode (negative) to 15
If you want Aux 2 to operate the cab lights wire the LED with suitable series resistor - LED Anode (positive) to 16 and Cathode (negative) to 14
If you want Aux 3 to operate the cab lights wire the LED with suitable series resistor - LED Anode (positive) to 16 and Cathode (negative) to 13
Standard LEDs have a longer lead as the Anode and their shorter one is Cathode (negative).
Always ensure you have a series resistor fitted. I would be looking for at least a 1K (1000 Ohm) 1/4watt. Higher Ohm value can be used to reduce the LEDs brightness.
Thank you for your help I will try this
