I have some N Gauge locos that i want to test before trying to sell them. I know one at least has a dcc decoder fitter. Can i use a dc test track to make sure it is running ok?
DCC on DC test track
Re: DCC on DC test track
Do you know if you changed the cv(29?) to prevent running on DC? If you havent, it should run on DC but that wouldnt say whether it runs ok on DCC. If you have no DCC equipment to test it, Id be inclined to take the decoder out and re instate the DC blanking chip then, test it on DC. If you dont have the DC blanking chip, is there anyone near you who can DCC test the locos for you.barney121e wrote:Hi
You might not get the best price for your stock if you say they're DCC fitted but only tested on DC.
Can test as have both types of equipment, but not totally sure which locos are Dc and DCC. Will spend an evening in the week working out which is which.centenary wrote:Do you know if you changed the cv(29?) to prevent running on DC? If you havent, it should run on DC but that wouldnt say whether it runs ok on DCC. If you have no DCC equipment to test it, Id be inclined to take the decoder out and re instate the DC blanking chip then, test it on DC. If you dont have the DC blanking chip, is there anyone near you who can DCC test the locos for you.barney121e wrote:Hi
Does your DCC system have a programme track output? If so put each loco in turn on the programme track and make an address change. If no decoder is present the DCC system will report a fault code for 'no decoder'. Those that have a decoder can then be tested on DCC, those without a decoder on DC.
All sorted thanks. And all headed to ebay.
You might find some buyers here on the forum rather than going through the faff of the bay.
