Newb from South Africa
Welcome to New Railway Modellers Forum. Read the Introduction and Terms and conditions of New Railway Modellers model railway forum. Introduce yourself to the members in this section.
WilliamC
Post by WilliamC »
Hi everybody. Although I've admired model railroads from childhood, I have only recently decided to get involved in the hobby. As a total newbie, I will be relying on you guys' input quite often. So far, I can tell you the following:
1. I have 260 x 130cm space.
2. I have decided on a South African setting as that's where I am from.
3. I will be using HO scale with Lima being my choice of brand for rolling stock and locos.
4. I have a very limited budget, so will be using used/scratch-built items for now.
Having budgetary restraints, I decided to buy bits and pieces as they come up.
I have kicked off by acquiring track, small shunter and a few goods wagons, all S.A.Raiways from Lima.
I still have a long way to go before thinking of a layout, although I have some ideas on that.
Thank you for accepting me and I am looking forward to learning from you guys.
WilliamC
Re: Newb from South Africa
Post by WilliamC »
Ek wil ook net aan die lede van Nederland se, ek praat ook Afrikaans. :D
Ironduke
Post by Ironduke »
Hello William, welcome to NRM.
have you seen this sight http://trains4africa.co.za/ ?
WilliamC
Post by WilliamC »
Hi Rob. I havent, and it seems to be down at the moment, but I will definitely check it out again later. Thanks!
ChrisGreaves
Post by ChrisGreaves »
WilliamC wrote:Hi Rob. I havent, and it seems to be down at the moment, but I will definitely check it out again later. Thanks!
My experience too.
"Layouts Operational" fails to load (two tries on separate days), but "Automation, Automation Basics" does load.
glencairn
Post by glencairn »
Hi WilliamC. Welcome on board.
Daniel
Post by Daniel »
Hi William
Welcome!
Lack of budget and space made a scratchbuilder of me.
Now, at seventy, I thank for that and would not choose anything else even if I win the lottery.
I met several Southafrican fellows and was astonished by how they were able to see plenty of posibilities in every piece of the most simple material such a discarded plastic bag, a broken glass and so on. Delightful and very inspiring.
Can't wait to see what you build.
Daniel
My new Flickr:
https://www.flickr.com/photos/158027525@N08/
My old Flickr:
https://www.flickr.com/photos/daniel_1_32_scale/page223
Being right is one thing, but being true is quite another.
