1/32 Scale Diorama
Daniel
Re: 1/32 Scale Diorama
Post by Daniel »
My new Flickr:
https://www.flickr.com/photos/158027525@N08/
My old Flickr:
https://www.flickr.com/photos/daniel_1_32_scale/page223
Being right is one thing, but being true is quite another.
Daniel
Post by Daniel »
ImageDSCN7136 (2) by Daniel Osvaldo Caso, on Flickr
But before that the making of the Spanish (actually Arab) roof tiles.
I love such tiles but there are no afordable commercialy available ones for 1/32 or 1/35 so for years I have been using self made plaster castings from a many years no more in production protoype from MK-35. Taht was the very best I had seen but still the lower edges of the roofs where massive and I wanted the visible arranging of the individual tiles to be seen.
I tried "Diorama Debris" silicone moulds and the very expensive special super hard terracotta colour plaster. The tiles were perfect but casting them was a lot of work and removing the 0,5mm plaster castings from the mould without damaging the tiles was ... (No Daniel, you are not allowed to use such words in this forum.)
So I started searching a way to make my own and after 15 years this project generated a great result where the guillotine plays an essential roll.
ImageP1200771 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200772 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200774 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200800 (3) by Daniel Osvaldo Caso, on Flickr
ImageP1200776 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200778 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200820 (3) by Daniel Osvaldo Caso, on Flickr
ImageP1200824 (3) by Daniel Osvaldo Caso, on Flickr
ImageP1200821 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200825 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200826 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200827 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200828 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200829 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200830 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200831 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200832 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200834 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1200835 (3) by Daniel Osvaldo Caso, on Flickr
It is not difficult work but a bit boring if you don't have some good, tranquil background music. But I will use the same mnethod soon again.
ImageDSCN7139 (2) by Daniel Osvaldo Caso, on Flickr
ImageDSCN7137 (2) by Daniel Osvaldo Caso, on Flickr
ImageDSCN7144 (2) by Daniel Osvaldo Caso, on Flickr
ImageDSCN7145 (2) by Daniel Osvaldo Caso, on Flickr
ImageDSCN7146 (2) by Daniel Osvaldo Caso, on Flickr
ImageDSCN7149 (2) by Daniel Osvaldo Caso, on Flickr
Another jump:
ImageDSCN7197 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
ImageDSCN7206 (2) by Daniel Osvaldo Caso, on Flickr
ImageDSCN7208 (2) by Daniel Osvaldo Caso, on Flickr
ImageDSCN7212 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0102 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0103 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0105 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0108 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0110 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0111 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0113 (3) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0118 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0119 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0124 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0125 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0127 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0128 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0129 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0136 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0132 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0133 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0135 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0140 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0141 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0142 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0143 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0144 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0145 (2) by Daniel Osvaldo Caso, on Flickr
Jump to the bridge scaffold:
I decided to let go the card 'iron' brackets and asked Tim Williams (the fellow responsible for the 009 slate layouts and more at the Bala Lake Railway: https://bala-lake-railway.co.uk/) to make for me a set of much smaller 3D printed ones that would look much better.
And he did:
ImageIMG_0003 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
ImageIMG_0077 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0078 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0079 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0081 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0082 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0083 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190258 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0084 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0085 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0086 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0088 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0089 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0090 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0091 (3) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0093 (2) by Daniel Osvaldo Caso, on Flickr
Again:
If you look carefully you'll notice there are long strips of iron plate laying on the horizontal wood beams and following the ark shape. So I made some with thin card, paint and dry pastels:
ImageIMG_0170 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0172 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0173 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0175 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0177 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0179 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0180 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0181 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0184 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0185 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0186 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0187 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0188 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0190 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0193 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0194 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0198 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
Strips of 1mm thick balsa wood heavy weathered using diferent grades of sandpaper
ImageIMG_0200 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0201 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0203 (2) by Daniel Osvaldo Caso, on Flickr
They have all received a bath in China inkt diluted in water for the base dark gray -almost black- colour.
Some borads suffered more or less serious dammage as heavyly used scaffold boards would suffer:
ImageIMG_0204 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0205 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0206 (2) by Daniel Osvaldo Caso, on Flickr
Dry pastels help a lot to give some more apprpopriate tone to the boards but the dark base works accentuating for the eyes the deoth of the 'old' wood grain:
ImageIMG_0208 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0209 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0210 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0211 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0001 (2) by Daniel Osvaldo Caso, on Flickr
I took care of not repeating again and again de same spots (variation is music for the eyes!)
ImageIMG_0002 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0004 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0005 (2) by Daniel Osvaldo Caso, on Flickr
and here and there I touched the board with some ocker pastels to suggest recently exposed wood:
ImageIMG_0006 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0007 by Daniel Osvaldo Caso, on Flickr
ImageIMG_0009 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0010 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0011 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0013 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0014 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0015 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0016 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0017 (2) by Daniel Osvaldo Caso, on Flickr
As you see, the new limestone blocks for completing the repairs of the bridge have arrived:
ImageIMG_0018 (2) by Daniel Osvaldo Caso, on Flickr
They were cut from the same 'sculpture block' foam used for the two big pieces of the bridge:
ImageIMG_0020 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0021 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0023 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0025 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0007 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
I keep quoting this photo because is the only prototype image I've got but contain polenty of subtle information:
For example that a narrow gauge track was laid at the top for moving materials. So this diorama must have one too.
ImageIMG_0027 (2) by Daniel Osvaldo Caso, on Flickr
Since it is not a railway diorama but a diorama where a portable railway is being used for the repairs of the bridge, it must have also portable track
ImageIMG_0028 (2) by Daniel Osvaldo Caso, on Flickr
and appropriate sup[port structure
ImageIMG_0029 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0032 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0033 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0034 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0035 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0003 (3) by Daniel Osvaldo Caso, on Flickr
That was going to go well with a little work and once some big and small details would be added it would look at least a bit convincing so I started to think about that and got some stuff for it:
ImageIMG_0043 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0040 (2) by Daniel Osvaldo Caso, on Flickr
But something was missing yet...
A small crane!!!
I started to search thinking I would build one :
ImageIMG_0033 (3) by Daniel Osvaldo Caso, on Flickr
but that made me face once more my eye's issues.
I thought may be I can still build a kit...
And found the very l9ight 3ton crane made by Miniart. I bought one.
I tried to build it but my eyes couldn't see half of what was needed and my built became a frustration.
Specially because the Miniart kit is really an absolute beauty...
So I abought another two of the same kit (the prince was a little less than 10 euro each) and asked John Vogelaar to build them for me. He built one, his doughter the other. They made two jewels of it and if I manage to find the photos I'll post them in next message later today.
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
This is the Miniart 3 Ton crane kit
https://miniart-models.com/new-photos-o ... =1&slide=8
It is made to go with a truck not for a railway but I decided building a simple small wagon fro the crane was something I wanted to try. So I did.
John gave me the kits painted with just a layer of black primer, as I asked and soon I managed to get the little beauty on track on a special built platform wagon:
ImageIMG_0008 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0012 (2) by Daniel Osvaldo Caso, on Flickr
Here the other kit built still in the black primer beside the completed one:
ImageIMG_0024 (2) by Daniel Osvaldo Caso, on Flickr
and here the crane being opperated by a modified WWII soldier:
ImageIMG_0019 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0038 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0039 (2) by Daniel Osvaldo Caso, on Flickr
For my eyes I consider this a feat:
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
Well, actually this thread will temporarilly stop here because since 12 July I didn't touch the diorama again. The reason?
Seeing that I was no more able to build a small kit terrified me making me aware of how fast had de state of my eyes worsened.
In panic, some people tend to hide or run away or simply give up. Well, that's not my nature so I decided it was time to seriously check my not nice but real new boundaries. So I started building the freelanced 'ROWAN' style steam railcar that had been waiting at the top of my to-do list for a couple of years.
May be it will get and own thread one day.
So far I like the build but also realize how limiting my eyes are working. Enlarged photos can be very cruel.
The good niews was that, finally, the specialists decided to solve the problems in both eyes with a laser intervention. That would happen on 1st Oktober.
Well, I went to the Hospital that day just to hear that de intervention was being delayed to 2021. (Blame Covid for it.) So I must wait and once the virus stops drowning the health service I will get my 'new eyes' and be able -I hope- to build a second but more acceptable version of the steamrailcar.
In the mean time if anyone -and specialy beginners- has any questions, comments, critics, doubts or whatever related to the diorama, please do and you'll be welcome.
Daniel
Here the still incomplete railcar:
My new Flickr:
My old Flickr:
Ex-Pat
Post by Ex-Pat »
That's a real shame Daniel - but it gives us something to look forward to.
Meanwhile, I am wondering, and you probably are too, why there has not been much response to your fascinating thread.
Now, I am not a "scenery man" (much more interested in prototype locos etc..) and rarely look at posts in the "Scenery" Section. (But I'm glad that I did this time.) It strikes me however that perhaps if you were to move the thread to "Personal Layouts - Construction" when you resume modelling, then I imagine you will get more exposure and interest - just a suggestion.
Daniel
Post by Daniel »
Ex-Pat wrote:That's a real shame Daniel - but it gives us something to look forward to.
Thank you again, Ex-Pat.
Indeed, I was wondering if this forum would have just three or four members. So thank you for opening my eyes.
Great to know that we are not the last Mohicans.
I don't think I'll move this thread in order to catch some interest. Those few who are interested will some way smell or hear about and will show up.
But I am going to start a separate layout thread today.
Again, thank you for your attention, your advice and your inspiring modelling.
Daniel
My new Flickr:
My old Flickr:
Nevadablue
Post by Nevadablue »
Amazing work as usual Daniel.
That crane operator is a brave man. :D
Daniel
Post by Daniel »
Thank you, Ken.
Good to hear you like it.
Yes, the krane operator is really someone, not a puppet.
Daniel
My new Flickr:
My old Flickr:
