wanted
3raildriver
wanted
Postby 3raildriver » Fri Apr 05, 2019 5:36 pm
Wrenn rear trailing bogie for a wc spamcan and Armeture
Sure and Steadfast
alex3410
Re: wanted
Postby alex3410 » Sat Apr 06, 2019 7:05 am
Request moved to wanted section
3raildriver
Re: wanted
Postby 3raildriver » Sun Apr 14, 2019 3:40 pm
Its the rear pony i need not the bogie.Iam not sure if it is the same as a HD wc pony one but wrenn changed the conection with a pin on the draw bar instead of on the tender chassie
Sure and Steadfast
DevonRepairman
Re: wanted
Postby DevonRepairman » Fri Jul 05, 2019 8:07 am
Do you require a 3 pole or 5 pole armature?
3raildriver
Re: wanted
Postby 3raildriver » Sat Oct 19, 2019 1:46 pm
No longer needed as i now have all thge origanal parts required to build the Wrenn Spamcan
Sure and Steadfast
Return to “Items Wanted”
