Hello
Not been here for a while so here I am with a new issue.
Part of my layout requires 3 parallel tracks after a 3-way point (Peco SL-E99). I need to use standard straight track for the middle track. My problem is that I am not sure what small curves to use for the left and right tracks so I can make all three parallel. Any ideas?
All the best
Patrick
Peco 3-way Point
Re: Peco 3-way Point
For something this simple try SCARM to design it. It's free upto a certain amount of tracks.
https://www.scarm.info/index.php
To overcome the track pieces limitation in the software for my layout, I replaced all the straights with flexitrack pieces.
So say, 3 straight pieces replaced by ONE flexitrack peice in the software reduces the number of track peices to 1 from 3 thus giving you more to work with.
Hope it helps
Hope it helps
If that's Streamline rather than Setrack it won't fit the standard Setrack curves. Use flexi instead, you can get a gauge to keep the spacing correct and a straightedge helps you lay it straight.
Don't forget that the Peco SL-E99 Electrofrog 3 way point has to have some form of frog polarity switching fitted to both its frogs.
The Insulated frog version SL-99 doesn't need this.
![Image](https://farm2.staticflickr.com/1902/45122449624_0948ef6939_t.jpg)
The 3 way point is 610mm radius and a 12 degree angle so you need a curve of those dimensions to straighten out - as above flexible track is the simplest solution - if you really need to use setrack I would suggest a 4th radius curve cut to the degree angle and a short straight (Hornby R610 or Peco ST203).
- NedFlanders
Hi there,
I used a streamline medium (I think) point attached to either diverging route to give me the template for the curve back to parallel running . I marked the route on to the baseboard and then laid it with flexitrack.
This post has a photo of the unballasted result viewtopic.php?f=22&t=52479&start=30#p658971
It has worked away fine for me. I will be doing it again shortly and can do a mockup for you to make more sense if that would be helpful?
Ned.
Ned.
