Greater Loftchester
Michaelaface
Re: Greater Loftchester
Postby Michaelaface » Mon Sep 03, 2018 1:45 pm
Dad-1 wrote:Hi Michaela,
Now this one is going to keep you busy for a LONG time !!
Moving from Budget to Sound ! I hope your current job pays
well.
That is quite a large space to have available, lucky old you.
aha "sound" I just thought I'd try out some of those TTS decoders, still trying to decide if it's worth delving further down that rabbit hole, besides I should really get everything finished before messing about with that, and I'm still on a budget! I've hardly bought anything for this layout so far, been able to recycle almost everything from my old ones, the only "big" cost is that I've had to replace all of my C&L track (it had been used on 3 layouts, plus it was a nightmare to ballast) also I'm still going to be using the section where I build all the track myself (which is the next task)
Michaelaface
Postby Michaelaface » Fri Sep 07, 2018 1:41 am
Started work on getting the automation set up on my layout, here’s a video
https://youtu.be/ENRUZd5E8Tc
Postby Dad-1 » Mon Sep 10, 2018 8:57 am
Hi Michaela,
Nice, but I'd like to see where & how your automation holds and rotates traffic.
Montfort
Postby Montfort » Mon Sep 10, 2018 9:21 am
Seems that automation works fine: https://www.youtube.com/watch?v=gTT7k-N1qfU
Back on the track !
Michaelaface
Postby Michaelaface » Mon Sep 10, 2018 2:42 pm
I see Montfort has beaten me to it and already posted the time-lapse video I made of my fiddle yard :lol:
Postby Dad-1 » Mon Sep 10, 2018 9:14 pm
Thanks for that, quite impressive.
Postby TimberSurf » Mon Sep 10, 2018 11:02 pm
Yes, I too was wondering how different trains were using the same track, very good! :) Clever idea to use the time lapse too!
Michaelaface
Postby Michaelaface » Thu Sep 20, 2018 6:30 pm
should probably get some photos into this thread
Here are a load of station buildings I've been working on
Fiddle yard trackwork
and the longest train I can get into said fiddle yard
Dublo
Postby Dublo » Thu Sep 20, 2018 6:41 pm
Wow very nice all looking good there Michaela.
Postby Dad-1 » Thu Sep 20, 2018 8:44 pm
Hi Michaela,
Very neat and clean construction.
I do like your weathered one at the back.
Montfort
Postby Montfort » Fri Sep 21, 2018 10:28 am
Well done. What kind of points did you use ?
Back on the track !
Michaelaface
Postby Michaelaface » Sat Sep 22, 2018 2:02 am
thank you everyone, and the points are peco code 75 small points
Montfort
Postby Montfort » Sat Sep 22, 2018 9:16 am
Michaelaface wrote:...and the points are peco code 75 small points
Thanks.
Back on the track !
Michaelaface
Postby Michaelaface » Sat Oct 13, 2018 12:32 am
Give me some thoughts please fellow modelers, I keep putting off building the next sections to my layout, here's why
The terminus section, my plan for this would be that I'd build all the trackwork myself, I started this task and it was all looking great! then a slight accident with some plastic weld melted a small part of the pointwork, but the thought of having to rebuild that section completely destroyed my motivation, so my question here is, do I persevere and build the track here, or do I just buy some RTR points and get on with it, broken down a bit more this argument is time vs money, I'm leaning more toward just buying points now as I just want to get a move on with the whole lot, but it does mean spending a bit more money than I'd intended
The second thing I've been putting off is the raised section, firstly, I'm not sure what height to commit to with this, I've worked out there need to be a clearance of around 8-10cms for trains, but do I want minimum or do I go a bit higher? but with higher would that blend in with the lower scenery as well? and as for the track plan I'm not sure whether to keep the top level pain like the lower level or add in some points for scenic interest
thoughts gang?
Postby TimberSurf » Sat Oct 13, 2018 7:40 am
Re pointwork, as you have the skills, could you not cut a section out and repair it? (pictures, please)
Re height, what you have laid is not quite as per the previous diagram, could you give us an up to date diagram? I have issue with the previous diagram that the upper track would be obscuring access/sight to the lower track.
You need 6mm (better 12mm) above your highest train clearance for structural thickness and a bit of reality, but height always tends to be compromised to be the absolute minimum to keep the the interconnecting incline gradients as shallow as possible, if the two levels are not connected, then it can be as high as you like!
The use of rocky cliffs and retaining walls will assist with the scenic connection between the two.
Users browsing this forum: No registered users and 32 guests
