Hi guys playing with the idea of a n gauge lay out in my shed.
It's 8x6ft standard apex.
Any thoughts on what I could do? May b even a pic?
Thanks in advance
N gauge shed ideas guys?
Re: N gauge shed ideas guys?
Probably round the edge would be most practical.
Yes I'd say round the edge, keep the boards fairly high with the backscene protecting the section in front of the window from strong sunlight. Then you can still have your workbench under the window.
You could make a model of an N scale shed. A shed in a shed.
- Ironduke
You first. Maybe even a floor plan? There are plenty of keen planners in the forum.atnas666 wrote: It's 8x6ft standard apex.
May b even a pic?
Ha ha shed in a shed will be on the plan .
As for track plan I was hoping u guys would help. Definitely needs a loop or 2
- luckymucklebackit
If you are modelling modern image, build a loco depot and get a class 66, then you can have a shed in a shed in a shed
Best of luck with the project.
Hay guys canceling this shed build for the moment.. Change of plans
