The Little Big Eight
Re: The Little Big Eight
Postby Mountain » Tue Jun 19, 2018 8:52 pm
The issue here is that I believe Longvallon is modelling in 7mm narrow gauge. The chassis of the 4 wheel coaches can be used. Unless Longvallon wants to run both 7mm narrow gauge and 00 gauge together?
Longvallon
Postby Longvallon » Tue Jun 19, 2018 8:59 pm
Nice work with your coaches. But I like to keep my locos and my rolling stock exactly as they are.
Don't take life so seriously, you'll never get out of it alive.
Longvallon
Postby Longvallon » Tue Jun 19, 2018 9:22 pm
Mountain wrote:The issue here is that I believe Longvallon is modelling in 7mm narrow gauge. The chassis of the 4 wheel coaches can be used. Unless Longvallon wants to run both 7mm narrow gauge and 00 gauge together?
I'm playing in On30, HO and in a few days, in OO. That's all folks !
Postby End2end » Tue Jun 19, 2018 11:32 pm
Longvallon wrote:Nice work with your coaches. But I like to keep my locos and my rolling stock exactly as they are.
No problem Longvallon. I just thought I'd share the idea. :wink:
Longvallon
Postby Longvallon » Fri Jun 22, 2018 9:44 am
My new stuff is on the track ! :D
https://www.youtube.com/watch?v=QQtrQMNVpL0
Postby End2end » Fri Jun 22, 2018 11:14 am
You just need a load for the wagon now. :D
Longvallon
Postby Longvallon » Fri Jun 22, 2018 11:44 am
A few big nuts will do the trick:
Longvallon
Postby Longvallon » Thu Jun 28, 2018 10:18 am
I bought two other Hornby blue coaches (I like this blue):
https://hattonsimages.blob.core.windows ... Qty1_1.jpg
I removed one hook on each one. My train with three coaches runs better than ever.
Postby Emettman » Thu Jun 28, 2018 11:44 am
Longvallon wrote:I bought two other Hornby blue coaches (I like this blue):
Yes, the tighter the curves the more critical coupling choices become.
Alternately if small inconspicuous couplings are a priority then there may be less freedom to use tight curves.
"Want Both" is not impossible, but it can mean the underside of wagons and coaches gets complicated, or the ability to break up trains is sacrificed.
I modified my own Hornby couplings to one hook, centred, with a delayed uncoupling action.
The sacrifice there (as with your coaches) is that the stock is single-ended. No return loops or fiddle yard train turntables can be allowed.
Longvallon
Postby Longvallon » Fri Jun 29, 2018 11:17 am
Bad news. My cheap Mehano controller doesn't work anymore. Yesterday, I put a very old Roco diesel on the track. This locomotive ran well for a few minutes when my controller started to smell a very disgusting odour and die. :evil: Right now I'm using an old Bachmann controller and everything works fine. :D
Now I'm looking for a Gaugemaster controller: http://www.hattons.co.uk/62795/Gaugemas ... etail.aspx
Postby Mountain » Fri Jun 29, 2018 12:03 pm
That should do the trick. :)
Longvallon
Postby Longvallon » Fri Jun 29, 2018 3:15 pm
Thanks. I think so too.
Longvallon
Postby Longvallon » Sat Jun 30, 2018 6:20 pm
My new little blue train (Click on the photo to see a larger picture).
Postby Mountain » Sat Jun 30, 2018 7:44 pm
That looks nice. Very nice. :)
Longvallon
Postby Longvallon » Sun Jul 01, 2018 7:41 am
Thanks. :D
Users browsing this forum: PinkNosedPenguin, smeghead28 and 19 guests
