Arduino controlling servos help needed
Paul-H
Postby Paul-H » Thu Jun 07, 2018 11:12 pm
Hi all
I need some help from someone who understands how to write Arduino Sketches because I don't have a clue :roll:
So I have both UNO and MEGA boards which I use with a number of freely available sketches for things like DCC control DCC++ and for stepper motor control of a Turntable and now I wish to use one to control servos for point control
I have one of these sensor shields which I understand can control 16 servos https://m.ebay.co.uk/itm/2009-Nano-v3-0 ... 3040433870 if that is correct could someone write the sketch for me.
All I will need is servos connected to the shield and each servo switched by a toggle switch with end point adjustment via a simple edit of the sketch , say zero to 180 Deg for the end to end throw which I can adjust in a text editor if I need less than full throw.
If what I want is doable without too much work or time could someone help
I am ok with connections and following instructions but don't have a clue when it comes to writing code, and with the signs of dementia starting I will not be able to learn, so anyone up for the challenge and be willing to help me.
Thanks in advance if anyone can help.
BuffyMcBuffer
Re: Arduino controlling servos help needed
Postby BuffyMcBuffer » Fri Jun 08, 2018 7:36 am
Timbersurf and another forum member (forgot his username) are currently helping people in a arduino programming thread
Check it out as the line crossing using servos is currently be covered at the moment so hopefully the coding will be written and an explanation on how is works is up
Paul-H
Postby Paul-H » Fri Jun 08, 2018 9:42 am
I have added this request to that thread in the hope that someone will see it and take pity on me and help :wink:
paul
Postby TimberSurf » Fri Jun 08, 2018 11:23 am
Timbologist is in Australia so his answers tend to be 12 hrs out from UK. :)
We will pick this up in the other thread
Buggleskelly
Postby Buggleskelly » Sun Jun 10, 2018 11:28 am
Paul-H.
I had the same issue re Arduino sketches. No doubt you have found it is almost impossible to find a pre-written sketch. Even one that you can modify or adjust yourself. I built an N gauge two gate module with two servos.
One suggestion that came up when I asked the same question, was to use one or two of those cheap servo testers. All you need is a simple 5 volt supply.
The only issue may be adding auto detection of a train using infra red or reed switch.
Postby TimberSurf » Sun Jun 10, 2018 12:31 pm
Once I have fully built my level crossing and proven the code, i will release it for all.
I have proven it in a simulator, but have yet to find time time to add the sound.
I will also build and program one for swing gates too :)
peroni
Postby peroni » Mon Jun 11, 2018 5:52 am
Hi Paul,
This should help you out:
This project controls 8 servos with corresponding start and
stop positions using push buttons. The starting positions are
determined by sstart-25,25,25,25,25,25,25,25 and the stop
positions by sstop-160,160,160,160,160,160,160,160
Each push of the corresponding button causes the servo to seek
the opposite position and changes the state of the corresponding
LED, using the pushbutton/LED connections pictured:
Connected pins: servos - spins - 2, 3, 4, 5, 6, 7, 8, 9;
pushbuttons - pins - 11, 12, 14 (A0), 15 (A1), 16 (A2), 17 (A3), 18 (A4), 19 (A5)
Here is the Sketch:
// MRH 8 Switched 8 Servos with Pushbuttons & LED Indicators
// G. Bunza 2016
#include <SoftwareServo.h>
#define numpins 8 // Number of Servos
SoftwareServo servo[numpins] ;
int i,k,l;
int pins [ ]= {11,12,14,15,16,17,18,19}; // Pushbutton/LED pins
int spins [ ]= {2,3,4,5,6,7,8,9}; // Servo pins
int sstart [ ]= {25,25,25,25,25,25,25,25}; // Servo Start Positions
int sstop [ ]= {160,160,160,160,160,160,160,160}; // Servo Stop Positions
boolean pinval [ ]= { true,true,true,true,true,true,true,true }; // Servo State
void setup() {
for (i=0; i<numpins; i++) {
servo[i].attach (spins[i]); // Set up servo controls
servo[i].write(sstart[i]); // Set each servo to start position
pinMode(pins[i],OUTPUT); // Initialize PB/LED pins
digitalWrite(pins[i],HIGH);
void loop() {
SoftwareServo::refresh(); // Must Refresh the Internal Servo Control
pinMode (pins[i],INPUT_PULLUP);
if (digitalRead(pins[i])==LOW) { // Check if a Pushbutton is pressed
pinval[i]=!pinval[i]; // Assume only one at a time
if (pinval[i]==true) servo[i].write(sstart[i]);
else servo[i].write(sstop[i]);
while (digitalRead(pins[i])==LOW) {SoftwareServo::refresh(); } // Wait until PB is released
pinMode(pins[i],OUTPUT); // Now go back to maintaining LEDs
digitalWrite(pins[i],pinval[i]);
Switch with led.jpg (17.19 KiB) Viewed 718 times
Paul-H
Postby Paul-H » Tue Jun 12, 2018 2:19 pm
Thanks for that, will give it a go when all the parts arrive.
Paul-H
Postby Paul-H » Wed Jun 13, 2018 2:09 pm
Getting an error loading that sketch, although its probably me not understanding how to add it
Could you add it as a zip file so I can have a full copy to upload
Paul-H
Postby Paul-H » Wed Jun 13, 2018 10:04 pm
So assuming that this is the scetch contents, how do I convert it to something the Arduino IDE will load and compile successfully.
// G. Bunza 2016
int i,k,l;
void setup() {
void loop() {
I tried copy and paste, putting in its own directory etc but keep getting a fail on compiling?
Thanks for any help with this
peroni
Postby peroni » Wed Jun 13, 2018 11:14 pm
Hi Paul,
Just copy the sketch file, use you mouse to highlight it, then paste it into the arduino program window, when you compile it, it will ask you to save it and you can call it anything you like.
Arduino window.jpg (103.49 KiB) Viewed 635 times
Paul-H
Postby Paul-H » Thu Jun 14, 2018 8:58 am
I tried that that and got the following error message, can you see anything obvious in that message
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
D:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries D:\My Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10805 -build-path C:\Users\pshar\AppData\Local\Temp\arduino_build_252412 -warnings=none -build-cache C:\Users\pshar\AppData\Local\Temp\arduino_cache_564700 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=D:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=D:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=D:\Program Files (x86)\Arduino\hardware\tools\avr -verbose D:\My Documents\Arduino\sketch_jun14c\sketch_jun14c.ino
D:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries D:\My Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10805 -build-path C:\Users\pshar\AppData\Local\Temp\arduino_build_252412 -warnings=none -build-cache C:\Users\pshar\AppData\Local\Temp\arduino_cache_564700 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=D:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=D:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=D:\Program Files (x86)\Arduino\hardware\tools\avr -verbose D:\My Documents\Arduino\sketch_jun14c\sketch_jun14c.ino
Using board 'uno' from platform in folder: D:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: D:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"D:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\pshar\AppData\Local\Temp\arduino_build_252412\sketch\sketch_jun14c.ino.cpp" -o "nul"
"D:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\pshar\AppData\Local\Temp\arduino_build_252412\sketch\sketch_jun14c.ino.cpp" -o "C:\Users\pshar\AppData\Local\Temp\arduino_build_252412\preproc\ctags_target_for_gcc_minus_e.cpp"
D:\My Documents\Arduino\sketch_jun14c\sketch_jun14c.ino:12:28: fatal error: SoftwareServo.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
peroni
Postby peroni » Thu Jun 14, 2018 10:58 am
Going by your printout, it looks like it is not finding the library files, when you install the Arduino program
it puts the arduino files in (windows10) Users\NAME\Documents\or My Documents\arduino
then the libraries are located in (windows10) Users\NAME\Documents\or My Documents\arduino\Libraries
i have attached the library files in a zip file, just unzip it and place the folder in the library folder then start the Arduino program and load
the sketch
Graham
SoftwareServo.zip
(4.1 KiB) Downloaded 10 times
SoftwareServo.zip
(4.1 KiB) Downloaded 9 times
Paul-H
Postby Paul-H » Thu Jun 14, 2018 1:39 pm
That did the trick, thanks for the help
Return to “Electronics”
