Painting advice needed
Michaelaface
Postby Michaelaface » Mon Sep 18, 2017 6:59 pm
Hey everyone, I have a couple of really dumb questions I can't seem to find answers to on google
What is the best/most efficient way to mix enamel paint and with thinners and the transfer that mix to an airbrush
Not talking about consistency or anything, I mean getting the stuff out of their respected containers
Right now I've been using a tamiya paint stirrer thing to move everything about but that takes ages, pouring just makes a big mess or is wasteful
Tried a pippette albeit a plastic one and it was predictably dissolved by the thinners
So I'd be very grateful if someone could fill in this basic knowledge I'm missing
Re: Painting advice needed
Postby Dad-1 » Mon Sep 18, 2017 8:29 pm
Hi Michaelaface,
Can be a damn messy job !! Probably one of the reasons I stopped using an airbrush
20 years ago.
I used to pour into a small jar over old newspaper where it was cut-back with thinners,
before adding to the side mounted reservoir thingy.
I loose so much paint by it drying out in the tin that losses by spillage were acceptable.
I suppose it was also the cleaning out afterwards I hated.
Postby TimberSurf » Mon Sep 18, 2017 9:46 pm
I use plastic pipettes with no problem in white spirit or humbrol thinners?
http://www.ebay.co.uk/itm/1-2-3-5ML-100 ... 1438.l2649
and http://www.ebay.co.uk/itm/Wholesale-Dro ... hash=item0 as the precise dropper for the thinners
Postby Bufferstop » Mon Sep 18, 2017 9:55 pm
Try acrylics, not the foul stuff that Humbrol produce, but artists acrylics either in tubes like oil paints or bottles like poster paint. You need to mix your own shades sometimes. Provided you start with the appropriate primer for the surface, metal or plastic, and finish with a matt or semigloss varnish it's far less trouble than enamel. Thinned with water and really well stirred it will spray in thin coats and build up to a good cover. Used as is it doesn't hold brush marks like enamel, and if you don't like the results warm water and an old toothbrush will remove it, before varnishing, that is.
David Bigcheeseplant
Postby David Bigcheeseplant » Mon Sep 18, 2017 9:59 pm
Use a battery powered ikea coffee frother (£1) to first mix the paint in the tin or jar then decant into an old 35mm film container where white sprit then mix again and transfer to airbrush.
David
flying scotsman123
Postby flying scotsman123 » Mon Sep 18, 2017 11:54 pm
I'm surprised the thinners dissolved the plastic. Even the really strong solvents we use for painting the 12" to the foot models only dissolve plastic after a few hours. I've used pipettes with no problems with white spirits, and even occasionally for plastic weld very quickly without any harm.
Postby Mountain » Wed Sep 20, 2017 1:57 pm
David Bigcheeseplant wrote:Use a battery powered ikea coffee frother (£1) to first mix the paint in the tin or jar then decant into an old 35mm film container where white sprit then mix again and transfer to airbrush.
David
What's happened to the 35mm films these days. Though I've not used my cameras for a few years now, I'm not sure where to send films off to be developed. Is Tru-Print still going? Umm.
Not sure where to buy batteries either. :/
Postby TimberSurf » Wed Sep 20, 2017 5:11 pm
For "35mm film container", read plastic shot glass (Tip 902), as they are like rocking horse poo these days! Max spielmann have high street shops you can still get film developed at, I think Boots still do it too, also available online but "We no longer develop B&W (except C41), Roll Film, Slide Film, 110, Disc or 126 films"
Postby Mountain » Wed Sep 20, 2017 8:00 pm
TimberSurf wrote:For "35mm film container", read plastic shot glass (Tip 902), as they are like rocking horse poo these days! Max spielmann have high street shops you can still get film developed at, I think Boots still do it too, also available online but "We no longer develop B&W (except C41), Roll Film, Slide Film, 110, Disc or 126 films"
Such a shame as the 110 was such a quick to use and change film it was ideal for taking train pics, especially if one had a manual thumbwind camera which were so fast to wind on....
Sorry. I've diverted the origional subject.
I used to be a fan of spray painting via the need to repaint bicycles, but these days I tend to prefer to brush paint. Having said that some applications need to be spray painted.
Postby Mountain » Wed Sep 20, 2017 8:14 pm
Has anyone tried one of those spray painting devices which run from mixing paint with lighter fuel?
Return to “Scenery”
