Track Weathering
harris
Track Weathering
Postby harris » Sat Mar 11, 2017 11:30 am
I have seen some videos on this but they use a spray gun not a brush - I wont be using a gun.
I plan to use railmatch sleeper grime and wonder does it need thinning - I will be using a brush not a gun.
I also bought Humbrol dark earth for the rails - again does it need thinning and should this be done in any order.
I have already ballasted the track.
I measure 5 times but still end up drilling twice
harris
Re: Track Weathering
Postby harris » Sat Mar 11, 2017 2:54 pm
I painted a piece of test track which has no ballast with the sleeper grime - looks ok but the rails still seam shiny.
Before and after
Ironduke
Postby Ironduke » Sat Mar 11, 2017 7:12 pm
You mean the tops of the rails? I think they would be shiny in real life unless the track is never used.
Ex-Pat
Postby Ex-Pat » Sun Mar 12, 2017 12:11 am
Another approach is to use items 7, 8 & 9 here: http://woodlandscenics.woodlandscenics. ... rPage=1900
They are tubes of paint complete with agitator and "nib" for weathering sleepers and the sides of rails. (I have found that the nibs can wear down quite easily - depends on how sharp your ballast is. Also you may need to touch up spots where the rails sit in the chairs with a small paint brush - however they certainly break the back of that exciting job!)
I certainly wouldn't paint the tops of the rails unless they were in disused sidings.
Although produced in USA these products can be found in the UK at many suppliers.
harris
Postby harris » Sun Mar 12, 2017 9:46 am
thanks I will paint the track sleepers with grime
harris
Postby harris » Sun Mar 12, 2017 3:57 pm
And here is my effort after painting with grime
Return to “Scenery”
