Removing saddle tank body
Harry
Postby Harry » Tue Dec 22, 2015 2:02 pm
Could someone please save my sanity and tell me how to remove the body of this Hornby saddle tank?
There is a metal clip on either side, but having teased them into what seemed to be every possible position, nothing is budging.
There is a single screw underneath, but removing that had no obvious effect.
Roger (RJ)
Re: Removing saddle tank body
Postby Roger (RJ) » Tue Dec 22, 2015 3:58 pm
On mine, once the spring clips are released, pull the front of the chassis DOWN which releases the rear clips (hooks)
Harry
Postby Harry » Tue Dec 22, 2015 5:37 pm
Thanks for those suggestions.
The blighter's still resisting tenaciously.
castlespitfire
Postby castlespitfire » Tue Dec 22, 2015 7:25 pm
Was taking body off my one and will only add one thing. Be ever so careful. One of the two rear clips snapped off my one. Not a big deal but annoying. They are brittle. Glued it back on with piece of plasticard. John
It was working yesterday last time I used it................... John
RAF96
Postby RAF96 » Thu Dec 24, 2015 3:15 pm
The curly wire clips hold the motor into the chassis.
The bodies of these little monsters are always two lugs at each end of the body easily released with a flat bladed screw driver and sustained pressure.
One end is the anchor and the other end is a pivot point.
RAF Halton Brat - 96th Entry
β-tester
Postby Bufferstop » Thu Dec 24, 2015 3:44 pm
If it's the tank in the photo the tangs to release are the ones that hook into the diecast footplate assembly. A second set hold the plastic upper body to the footplate. The plastic bodies of other 0-4-0s using the same chassis clip directly to it.
