My research leads me to several new conclusions, all against my oldschool experience!
Solid baseboard adds mass to deaden sound, add wood underneath along track path, (or add rubber foam below basebord). Could do as later addition
Cork underlay does not absorb sound, too dense and simply "connects" track "Accousticaly" to board. Use Depron foam or wood floor underlay instead.
Dont use track pins, as they too connect track "Accousticaly" to the board. Glue track to foam.
Dont use PVA glue for ballast! It again makes a solid mass that conects track to board (side gravel touching board defeats the foam). Use Copydex diluted with water and meths. (stays flexible when set)
So, glue Foam to board with PVA (does not move over time)
Tack glue, track to foam, with spots of evostick (holds track in position, even when wetted when ballasting)
Use diluted Copydex for ballasting (potential can allow track to move over time but evostick spots will stop this)
Please add comments if you think I am wrong!
![Embarassed :oops:](./images/smilies/icon_redface.gif)
But my question is, were do I get Depron from? I can buy 1200x800x3mm sheets from numerous sources on net, but they all have minimum order of 40 sheets at approx £2.25ea! (ensures transit as a pack does not damage boards)
There is one source who sell cut down sheets in smaller quantities, but they are white and I want the grey type!
I might consider buying a pack and sell on here, in smaller numbers, if there is an interest!
Any suggestions welcome
![Very Happy :D](./images/smilies/icon_biggrin.gif)
