SO!! Onto the planning - one of my first acts was to find an old map showing the track layout as it was and then I scaled it off into 1 foot squares. One of my next things was to go and take some photo's of the still existing fabric of the stonework and structures so that I could try and reproduce it as close as possible. To help with scale in the photo's I put to use a piece of spare plastic wastepipe that I had and marked it off every foot with red electrical tape. As you can see from the pics it worked quite well.
This picture clearly shows the two sizes of stonework will need to be used
I've seen somewhere on the forum tonight that platform height in N is 6.2mm from track which is pretty much supported by this pic
The next stage is going to be drawing up the photo's onto graph paper to help make the modelling a bit easier....at least I hope it will....
I haven't even started on the baseboards yet
