Painting Plastic
Pompey1950
Painting Plastic
Postby Pompey1950 » Tue Jan 13, 2015 3:35 pm
duplicate post
luckymucklebackit
Re: Painting Plastic
Postby luckymucklebackit » Tue Jan 13, 2015 3:39 pm
I use white matt car primer from the £1 shop, works well for me. It may be an idea to roughen the surface of the plastic slightly with some fine emery paper forst to give the paint something to key into.
Bushey Troughs
Postby Bushey Troughs » Tue Jan 13, 2015 3:41 pm
Get some acid etch primer, it gives the acrylic paint something to bite on. You can get a spray can of it from your local car parts shop.
COLIN.
Roger (RJ)
Postby Roger (RJ) » Tue Jan 13, 2015 3:52 pm
Also depends what type of plastic it is. Some just won't paint well, such as polythene.
skyblue
Postby skyblue » Tue Jan 13, 2015 4:25 pm
I know what you mean about acrylics looking very thin and patchy, both with enamel and acrylic paints. Some paints seem to be much better at covering surfaces than others. To be honest, I tend not to bother with a primer, but just use several coats of normal paint - unless the paint is particularly expensive, such as Phoenix Precision Paints.
I can only answer number 5: if you use acrylic primer, use acrylic paint, and if you use enamel primer, use enamel paint. This is, I believe, because layering different types of paints can interfere with the drying process, which can be very slow for enamel paints.
bike2steam
Postby bike2steam » Tue Jan 13, 2015 4:26 pm
Postby Bufferstop » Tue Jan 13, 2015 4:34 pm
Bike2steams primer is good stuff but may be a bit expensive for what you are planning. If this is the basic Hornby station rather than one from the Skaledale range the self coloured accessory parts are likely to be made of polythene. If they are a bit bendy rather than hard that's another sign. Polythene is a right ********* to paint, it's pretty much resistant to everything. I use polythene lids from packaging for mixing paint and two part glues, you just leave it for a week or so and next time you want to use it, give it a quick flex and the dried up residue falls off. If it's the fencing you want to paint you could try rubbing it with wire wool to roughen the surface then apply Humbrol number 1 grey primer. Once dry you could then apply acrylic in the colour you want. It still won't stand up to a lot of handling but should be good enough for a scenic item which you fit and forget.
Zunnan
Postby Zunnan » Tue Jan 13, 2015 4:46 pm
Automotive spray primers are probably the best suited to model applications, the Hycote (as linked to) or Halfords are probably the most widely available, the latter being my preference. Re. fumes, using spray primers is not recommended indoors at all, it is best done outside using a clamp of some description so that the piece can be put down to dry safely (and to prevent your hand going grey in the process!). Automotive paints are acrylic based, and when hardened are a good base for all types of top coat.
Postby Bigmet » Tue Jan 13, 2015 4:49 pm
I would want to go back a step and ask about the plastic the fence is made from. Is it a waxy feeling material that bends easily? If so it will never take paint that well, and is best left as is or binned. As Zunnan writes, about the best option for an undercoat is motor vehicle primer, Halfords rattle cans and the like. That will adhere / remain intact for longest, especially if you rough up the faces as much as possible with fine abrasive paper.
One of the things you will learn about Hornby is that their range is something of a mess. They have it all. Refined models that professional model makers would struggle to match, alongside cheap toy oriented items that they have been churning out since the year dot.
Painting the rail sides: enamel. Model enamels can go straight on metal, provided it is grease free. Don't though use 'bright rust' unless you want to represent brand new rail just laid and barely seen a train. Look at real track and you will see that the rail side is typically a dull grey brown tone, a mixture of stone and brake dust and general oil, shit and muck splattered onto the rail sides by multiple passing trains.
Postby End2end » Tue Jan 13, 2015 4:51 pm
I found a £1 can of grey automotive primer at £land.
Here is an example of my linka try outs with it as a base coat/primer.
It's quite dark but you won't see it once painted over.
EDIT: Just a note to say that Linka is plaster based not plastic. Thought i'd better mention it as I have kind of veered off subject onto some sort of shopping channel.
:lol:
luckymucklebackit
Postby luckymucklebackit » Tue Jan 13, 2015 8:37 pm
That is the stuff I use, I find it great value for money, they have it in Grey, White and Black. Unfortunately they do not have it in Red.
