Postby Dad-1 » Sun Aug 19, 2018 8:36 pm
Hi Jim,
Grab from Widnes NOW ? They had the early, as here at £10, a bargain (last time I looked - Yesterday)
They also had the later TOPS version at £9.50, but I wanted the earlier period markings.
Need to buy a few more kits as the evenings a drawing in and TV is such absolute rubbish !!!
luckymucklebackit
Postby luckymucklebackit » Sun Aug 19, 2018 9:38 pm
Dad-1 wrote:Hi Jim,
If my wife finds out I am blaming you :D 13 ton Hyfit steel open with sheet in BR bauxite and a 12 ton shock absorbing open wagon in BR bauxite ordered tonight.
Postby Dad-1 » Mon Aug 20, 2018 4:20 pm
Hi Jim,
I'm not worried - Too far over the border, heck we're almost next
to France !!
Postby Dad-1 » Tue Aug 21, 2018 9:08 am
I couldn't resist buying another of those Bachmann Hi-fit.
Then to compensate for having bought more RTR I added
4 more Dapol 16 ton mineral kits and 1 BR brake van kit
to my order !!
Well the evenings are already closing in and I need something
to do rather than watching TV.
Those Dapol brake van kits have a small damaged tooling fault
that you need to overcome, but for £5 ........... Once you know
how it's quite easily sorted.
Geoff T
Hymirl
Postby Hymirl » Thu Aug 23, 2018 6:23 pm
Dad-1 wrote:Those Dapol brake van kits have a small damaged tooling fault
May I ask the secret?
I'm planning on attempting some dapol kits to increase the wagon fleet without too much financial damage..
Postby Dad-1 » Fri Aug 24, 2018 11:26 am
Hi Hymirl,
I'll start the Brake Van next so this can be covered. It's where the running boards attaching tag
is at the wrong angle. First you need to soften the offending part, I do it with a wash of liquid
poly and then tease back into correct shape.
Anyway I have a LNER/BR ply 12 ton van to finish first, I'll add a picture later as I'm off out now.
Postby Dad-1 » Fri Aug 24, 2018 10:07 pm
Started a few days ago and now sitting ready for painting to begin. A
PC06A Parkside BR version of the LNER 12 ton ply van with 8 shoe brakes.
Looking quite good although always a few points to take note of. A nice
touch were the small protrusions to protect the van end strapping from damage.
They do point out the need to remove small moulding pips from the inner buffer
beams, if left these will foul the floor fitting, here cut away, but were like the one
remaining at the end tops.
Although not absolutely necessary it is better to add between 5 & 10 grams additional
weight. Here in the form of a sticky backed car wheel balance weight.
The kit provides a length of plastic rod for the brake cross shaft. It's rather too thick
and to open out would probably split the brake cylinder lever. I replaced with a length of 0.5 mm
brass wire.
Another problem could be the fitting of buffer heads. The buffer housing holes are too small
to accept the buffer shafts, drill out to enlarge for a usable match.
These kits come with mounting blocks suitable for Bachmann narrow tension-lock couplings.
They need to be mounted on some scrap to get correct coupling heights. Here being set to
my standard fitted height.
Painting soon ? Probably leave that until I have a few more to paint.
Next week it'll be that Dapol BR brake van.
Hymirl
Postby Hymirl » Fri Aug 24, 2018 11:15 pm
You make it look easy!I like kit building in general so I'm keeping at it. After I see how you do the brake van!
- Al
Postby Dad-1 » Sun Aug 26, 2018 8:38 pm
Right, I said I'd build another, but decided to look at the old pictures from 2015. They were NOT in my workbench ?
Eventually found in the kit building threads, but I never replaced the pictures that were lost when Photobucket went
on their self-destruct mission. So here we have a mixture of old and new.
First what you get in the kit, this is quite comprehensive for such a low outlay. My earlier kit had much less flash
and was moulded in a softer plastic.
On comparing with my Bachmann model and drawings it was noted that the chimney was on the wrong side. This also
meant that the torpedo roof vents had to be re-located.
This was when almost finished, kit issue decals. Note to loose roof, this was because it was made incorporating a
Train-Tech motion activated rear lamp where access to the interior is needed to enable the battery to be replaced.
Now to the 2018 purchased kit. Components were showing much more flash and some parts were broken. A result of
having used a much more brittle plastic. One side foot board had two breaks leaving me 3 parts to join together. The other
side foot board had one of the locating tags snapped off.
NOT a good start, but as an experienced modeller I've worked with more challenging components !!
There is however loads flash of on this 2018 kit that I have to trim away before going any further.
luckymucklebackit
Postby luckymucklebackit » Sun Aug 26, 2018 8:51 pm
Hi Geoff - the moulds must be just about life expired, I had a similar experience with the last water tank kit I built, loads of flash, it just means that the mould faces are worn and ideally need to be replaced. I wonder how much longer Dapol can use these before they become unsustainable, as all that flash equates to wasted raw material. If that point is reached, will they scrap and replace, doubtful.
Postby Bufferstop » Sun Aug 26, 2018 9:06 pm
The old Airfix tools have got into this state in the past. Dapol seem to get the worst couple refurbished every so often.
Hymirl
Postby Hymirl » Sun Aug 26, 2018 10:14 pm
You get what you pay for, but I hope these kits stay in production in some form. They are important for the hobby to have options outside of top quality top price RTR.
Postby Dad-1 » Mon Aug 27, 2018 9:42 am
I so agree with Hymirl, it'll be a very sad day when these moulds are given up as time expired.
Dapol must be aware that this kit is somewhat less than perfect and that I suppose is reflected
in the brake van being £1 cheaper than the less complicated 16 ton mineral wagon.
Although it's 3.1/2 years since my last build I don't think they'll have made enough to wear the moulds
any more. On the basis of that I believe it's the assembly of moulds and different viscosity of plastics
used that has resulted in subtle changes between issues of kit. This one has somewhat more brittle
components, without my intervention one cabin end was snapped through above the door, then with
my intervention I snapped off one of the side extension pieces. It was slightly out of line and previous
kits allowed much bending and twisting without ever snapping. Add to that the fractures in the footboards
I now know this is one brittle. Don't expect Dapol to be overly fussy about testing the reclaimed plastics
they use in manufacture, these are far from being critical components !! Just as well, because when you
see the pictures of other components you'll doubt how this one will run !!
I still try to keep to "Bob the Builder" mentality of "Yes we can !"
Still tonight should allow me to proceed .............
Postby Bufferstop » Mon Aug 27, 2018 3:01 pm
It would be interesting to know if any have been totally replaced whilst they have been in Dapol's possession. There have been some long breaks in the availability of some of the range. I know the story of what was originally the Lowmac + JCB, the tools had been sent off to be refurbished at the time of the Winsford fire, and they lost track of them. It was only when they asked about refurbishing another kit that they found out the tools were sat on a shelf waiting to be returned "and can we have your new address please".
Postby Dad-1 » Mon Aug 27, 2018 3:25 pm
To get good running you need the chassis to be as near to square as possible.
This includes fettling each individual part where needed. Here we see the two
solebars, not exactly what you need !
As far as I could ascertain 'by eye' the floor and chassis framework was not far out
These parts were joined on glass, under the pressure from a 4 pack of baked bean cans.
Strange the things that get used as tools !!
Right, how to straighten bent solebars and step boarding ? A rather basic tool in the
form of a stainless steel ruler, clips and hot water. Here a solebar - that badly bent one
in the washing-up bowl ready to pour boiling water.
After the heat, in fact before it had got cooler than comfortable for fingers, I took and
placed in the freezer. The result was an almost straight piece of plastic !
I decide that I could be economical in the use of boiling water by using a casserole tray.
Here we have the side step boards.
With as accurate a fit as I could get I joined the cabin sides and verandah ends. They suggest
building in the cabin door ends as this is done, but it's easy to slide in later while I decide if
I try adding windows from sheet material, or use glazing compound
In that last picture those cabin ends are just propped in place.
O.K a few decisions, do I add wire grab rails, or leave the raised detail to be touched in with
some white paint later ? On the last build I just added the four horizontal grab rails at the ends
made from bent dressmaking pins.
Some thinking needed ?
Return to “The Workbench”
