new 4th layout construction
hedgefordpete
Postby hedgefordpete » Wed Feb 12, 2014 4:07 pm
hi everybody , i hope this photo works? this is my new layout. the 4th on this baseboard. gone is the messy loose ballast and in with the pre-scatter underlay. all the rail joints have been soldered and flexi track replaced the set curves.
the station is in the planning stage, normally this is as far as i get. a short over track stage for a transport depot with a roadway down to track level. all digital, running three trains on three separate circuits with a forth track allowing shunting in the goods yard and engine sheds.
the problem with the last layout was that i had not planned for the station. after trying to squeeze it in and failing , the result is a complete new start.
after all these years i should have known better. always plan first........
regards pete.
Re: new 4th layout construction
Postby TimberSurf » Thu Feb 13, 2014 8:37 am
Looks great!
More pictures!
and maybe a track layout?
clivef5915
Postby clivef5915 » Thu Feb 13, 2014 9:17 am
Looks interesting from the photo.
I, and I'm sure a whole load of other modellers, had problems regarding track expansion last summer in the heatwave. Are you tempting fate by soldering all the joints?
viewtopic.php?f=22&t=40184/Bath Queen Square - as never was !
hedgefordpete
Re: night frieght
Postby hedgefordpete » Thu Feb 13, 2014 10:20 am
thanks for the comments, yes, i had a problem last year with some track distortion . it was only noticeable on the long straights. the summer did not last long enough for any changes to be made.
regards, pete.
hedgefordpete
Postby hedgefordpete » Fri Feb 14, 2014 12:31 pm
the start of the station layout, [ at night ]Image
hedgefordpete
Postby hedgefordpete » Fri Feb 14, 2014 12:56 pm
under construction.
hedgefordpete
Postby hedgefordpete » Fri Feb 14, 2014 1:00 pm
planned station.
hedgefordpete
Postby hedgefordpete » Fri Feb 14, 2014 1:03 pm
under instruction
hedgefordpete
Postby hedgefordpete » Fri Feb 14, 2014 1:07 pm
station area under construction.
hedgefordpete
Postby hedgefordpete » Fri Feb 14, 2014 1:13 pm
the brs. depot on the overstage in the far corner under construction.
