Hornby 2014 speculation thread
D605Eagle
Re: Hornby 2014 speculation thread
Postby D605Eagle » Mon Dec 16, 2013 1:26 pm
Hopefully they have seen the light with these 0-6-0 engines. If they are well priced I can see them flying out off the shelves as fast as H can make them.
D605Eagle
Postby D605Eagle » Mon Dec 16, 2013 1:32 pm
The locodrive Compound at last with a decent tender is on my buy list. They look so much better in black that crimson lake.
Old Man Phil
Postby Old Man Phil » Mon Dec 16, 2013 2:44 pm
I dont know if it's just the Illustration but it appears as though the 2-8-2, Dick of the North, has no slide bars fitted. and the piston rod simply goes in and out of the cylinder at an angle approx 45° to what it should be doing. Tell me it's not true. But, if so, that is pathetic.
Bushey Troughs
Postby Bushey Troughs » Mon Dec 16, 2013 2:54 pm
Are you looking at the Railroad, or R3207 Pre-production example?
COLIN.
Postby Bufferstop » Mon Dec 16, 2013 2:59 pm
Old Man Phil wrote:I dont know if it's just the Illustration but it appears as though the 2-8-2, Dick of the North, has no slide bars fitted. and the piston rod simply goes in and out of the cylinder at an angle approx 45° to what it should be doing. Tell me it's not true. But, if so, that is pathetic.
It's a single slidebar design Phil, it is there but almost hidden behind the valve gear.
Old Man Phil
Postby Old Man Phil » Mon Dec 16, 2013 4:50 pm
Yes thanks. I'm Aware that is 'should' have the typical LNER single Slide bar, but it's nowhere in sight on this Illustration. Also, There is no return crank linking the driving wheel coupling/connecting rod axle to the return crank gearbox which drives the cylinder valves. Looks like a bodge Job to me, or are the model builders and designers so young that they dont understand how all that 'stuff' moving around on the wheels works.
P2 Cock of the north.jpg (133.04 KiB) Viewed 1962 times
Bushey Troughs
Postby Bushey Troughs » Mon Dec 16, 2013 5:14 pm
Railroad version page 2. - R3207, £122.99 version page 3.
>>>>Cóck O the North<<<<
COLIN.
trainlover23
Postby trainlover23 » Mon Dec 16, 2013 5:15 pm
D605Eagle wrote:Hopefully they have seen the light with these 0-6-0 engines. If they are well priced I can see them flying out off the shelves as fast as H can make them.
I reckon the price will around £105 for both the 0-6-0s
Postby Bufferstop » Mon Dec 16, 2013 5:25 pm
Don't think it's designers or model builders more like publicity photoshop artists trying to make it look as though the wheels are spinning. Flipping between photos I think there's a chunk of the crosshead and slidebar still "attached" to the joint between piston rod and connecting rod, which have been rotated along with the wheel detail to try to create movement blur. The Valve gear rod above has dipped at one end to follow the crank (he got that right), but its shadow on the frame is still horizontal.
amsie
Postby amsie » Mon Dec 16, 2013 6:09 pm
Not much for the modern image modeller again, apart from new Mk2 Aircons. Wow just what we needed! :roll:
NNR.76079
Postby NNR.76079 » Mon Dec 16, 2013 7:45 pm
I think its a good year for preservation modellers but the prices are creeping up and up, especially if that design clever rubbish is still used
If it steam and runs on rails i like it.
If its big, red and goes 'NEE-NAW' i like it
Lysander
Postby Lysander » Mon Dec 16, 2013 7:52 pm
NNR.76079 wrote: the prices are creeping up and up
......and that, I'm afraid, is how it's going to be from now on. Unpalatable though it is, there is no earthly reason why prices in this hobby should not follow what is happening everywhere else. Oh that it was different........
Tony
NNR.76079
Postby NNR.76079 » Mon Dec 16, 2013 8:01 pm
Tony
that is true and I completely agree that prices should rise like everything else but how is the crosti 9F in the railroad range at £119.99? I thought railroad was supposed to be Hornby budget range
Postby Bufferstop » Mon Dec 16, 2013 8:12 pm
Old Man Phil wrote:Yes thanks. I'm Aware that is 'should' have the typical LNER single Slide bar, but it's nowhere in sight on this Illustration. Also, There is no return crank linking the driving wheel coupling/connecting rod axle to the return crank gearbox which drives the cylinder valves. Looks like a bodge Job to me, or are the model builders and designers so young that they dont understand how all that 'stuff' moving around on the wheels works.
Found a picture of 'tother side.
http://hornby.com/shop/2014-range/
Looks to me as they are too dozy to realise the left hand slide bar has fallen off.
ERMick
Postby ERMick » Mon Dec 16, 2013 8:51 pm
Had to smile at the fact that the A4s that were announced last year under the banner "The Great Gathering" have taken so long to arrive they've now been renamed "The Great Goodbye".
You never know, if they take much longer they may be able to rebrand them for the centenary of Mallard's world record :wink:
