Bill´s Railway World
Post anything here to do with Model Railway Photography
flying scotsman123
Re: Bill´s Railway World
Postby flying scotsman123 » Thu Feb 27, 2014 7:53 am
Thanks Jim, I'll read that. I've heard of super 4 track, but nothing before that aside from hornby's 3-rail efforts!
William Medland
Postby William Medland » Thu Feb 27, 2014 11:01 am
Sorry to hijack thread.
hijack as much as you wish Jim, a very interesting subject.
In my view as to why the name "Series 5" was not used, was simply because there were not enough catalogue numbers available in the 501 series.
How did Series 3 get its name? If we see the "Standard Track" as series 2 (1952-58), then it stands to reason that the original Rovex 1950-51 issue
(without fishplates) could then be seen as series 1.
Cheers, Bill.
I do firmly believe in general, that to be credible railway modellers, we need to at least understand the working
principles of the real life railway, even if we are unable to put them into practice in a model form.
Postby Bufferstop » Thu Feb 27, 2014 1:26 pm
I don't know as I've ever seen Rovex track. I don't know if it would have extended to point work. The moving frog was to accommodate the first versions of the Princess loco which featured plastic wheels and a single pair of sprung plunger pickups bearing on the track. The plungers would have fouled on the gap had a conventional frog been used.
William Medland
Postby William Medland » Thu Feb 27, 2014 2:04 pm
Some of my points do have moving frogs, I wondered why.
Standard track has the joiner to the right, early Rovex track has the joiner in the middle and the track can only join in one direction.
There are two very slight versions of the Standard track, very early Standard has "Patent Pending" and the later has a patent number.
Buggleskelly
Postby Buggleskelly » Fri Feb 28, 2014 9:03 pm
Just found an interesting link, with some useful pics of the joiners :-
http://www.tri-ang.co.uk/OONew/indexTrack.htm
William Medland
Postby William Medland » Tue Mar 04, 2014 10:59 am
As this sub-forum is about photographs of model railways, we seem to have taken it off topic so to speak.
Discussing the old Tri-ang track is very interesting in itself, so I have started a new thread......
viewtopic.php?f=22&t=45214
Cheers, Bill.
PanzerJohn
Postby PanzerJohn » Mon Jun 16, 2014 10:17 pm
Blimey Bill you pop up all over the place! You at W&P this year? cheers John
William Medland
Postby William Medland » Mon Jun 16, 2014 10:57 pm
PanzerJohn wrote:Blimey Bill you pop up all over the place! You at W&P this year? cheers John
No John, I am not doing any UK events this year........... but I am organizing my own event at a museum in Germany,
so far I have two groups attending next month, one of them are bringing five vehicles including an armoured personel carrier!
Anyway, what brings you to this forum........ or are you just stalking me :shock:
Best wishes, Bill.
William Medland
Postby William Medland » Sun Jun 29, 2014 2:09 pm
UPDATE TO MY LAYOUT
I am reducing my Triang track from double tracks to a single line. The space saved will now contain Hornby Dublo 3-Rail.
The Triang track and the Dublo 3-Rail track will run side by side, but obviously they cannot join or cross, as they are different systems.
This change came about because I obtained a Dublo 3-Rail locomotive from 1954, and wanted to run it.
Cheers, Bill.
Postby Dad-1 » Sun Jun 29, 2014 5:29 pm
Bill,
You are too easily diverted ........
Now I suppose you'll be looking for more 3 rail locos !!
William Medland
Postby William Medland » Sun Jun 29, 2014 7:04 pm
Yes Geoff, I could not have a loco on the shelf and not be able to run it :D
flying scotsman123
Postby flying scotsman123 » Sun Jun 29, 2014 7:12 pm
William Medland wrote:Yes Geoff, I could not have a loco on the shelf and not be able to run it :D
I know your problem, imagine my quandary when I found a OO9 loco :?
And Geoff, if I remember rightly, you started off here saying you would only be modelling blue diesels... :lol:
Postby Bufferstop » Sun Jun 29, 2014 8:59 pm
Hornby Dublo three rail, now that's real good stuff. It may not have looked so realistic, but it worked, usually faultlessly. I was horrified by the stalling and spluttering of 2 rail models of the time, my Dublo stuff never stalled on points or anywhere else.
William Medland
Postby William Medland » Sun Jun 29, 2014 9:25 pm
I have had this N2 loco on my shelf for about 25 years and I had never run it because I did not have any 3 rail track.
However, I purchased about 3 foot of Dublo track for 99p on e-bay (very lucky) and gave the loco a very short run
forwards and backwards and it went brilliantly.... wow, I have been hooked on Dublo 3-rail the last week or so.
Cheers, Bill.
glencairn
Postby glencairn » Thu Aug 14, 2014 7:50 pm
William Medland wrote:The four cats are a constant problem, they do understand that they are not allowed there,
because when I enter the room they storm out :lol:
When my layout was in the loft my four cats would race me up the loft steps. I lost most times! :oops: Trouble was they WOULD NOT come down voluntarily!
As for the grey Triang track ------ that took me back. I had a small layout using that type of track with a Princess Elizabeth loco running. :)
Return to “Model Railway Photography”
