Reusable, modular layout base in N-gauge
alan_r
Re: Reusable, modular layout base in N-gauge
Postby alan_r » Fri Apr 26, 2019 4:43 pm
The next small building is simply the end of a toothpaste box turned inside-out, a cap around the top painted grey and a window print stuck over the sides. Very quick and to be honest - good enough for what I want in this area, so I think this is the way to go for the line of office blocks here
Small simple building
They are certainly too far from the normal viewing position to worry about detailing. These are meant to be more like a scenic backscene, so in that respect they have much more 3D texture than a photographic sheet.
PinkNosedPenguin
Postby PinkNosedPenguin » Sat Apr 27, 2019 11:18 am
alan_r wrote:They are certainly too far from the normal viewing position to worry about detailing. These are meant to be more like a scenic backscene, so in that respect they have much more 3D texture than a photographic sheet.
Agreed - looking good 8)
joshv8
Postby joshv8 » Wed May 01, 2019 1:15 pm
A 3 dimensional backscene, very clever. I find myself more and more amazed every chance I get to check in on this thread!
alan_r
Postby alan_r » Sat May 18, 2019 7:47 pm
Following from the previous two buildings, I made a larger office block with a full cereal box cut to the height of my window print and turned inside out again. I also wanted to hide the end of the old scenic background board, so thought of using two toothpaste boxes, one either side of the board to fit over the end and form the 'transition'
Box scaling
The 'first draft' of the big office block with the window paper stuck on
Big office block - first draft!
This close-up view shows the curse of the PVA glue and paper/cardboard combination! I really must find an alternative glue as PVA is too wet and swells the cardboard, warping it. The grid pattern of the windows just exaggerates the waviness :( Since this building has such long unsupported walls, it offers little resistance to buckling in this initial unmodified form
first draft wobbly sides
alan_r
Postby alan_r » Sat May 18, 2019 7:58 pm
Rather than turn the toothpaste boxes inside out, I kept them whole for strength and simply wrapped them with a cardboard skin to hold them together and to support the print paper. Because the building will be higher than the backscene, the roof straddles the board and holds the top in shape. It also hints at a deeper building than the boxes used to make it
Skin around toothpaste boxes
Placed over the scenic board end and it works ok
Scenic board end cover building
A view from the rear shows it covering the end of the backscene
Wrapped around the board end
I fixed the warping of the big office walls by sticking a block of expanded polystyrene inside the box and weighing down a flat board on top overnight while it dried. It has certainly flattened the wall and holds its shape well. Unfortunately the paper wrinkled in the [top right] corner
Stiffened building, wrinkled paper
The wrinkle was fixed by sticking a patch over the corner
Patched wrinkle
Nicely recovered if I do say so myself! :D
alan_r
Postby alan_r » Sat May 18, 2019 8:11 pm
Sticking another window printed paper wrap around the end building finishes it off. This too bowed a little, but I can live with it as the walls are shorter and the distortion is less noticable. The building is floating in mid air a bit for now, but this will be covered by a wider low-rise building at the bottom, perhaps linking to the station?
Completed office buildings1
Completed office buildings2
Overall though I am pleased with my 3D office building 'backscene' and it creates a more interesting way to fill the gap between my old layout backscene and the new wider extension. :)
The cardboard was all rubbish that would have gone into the recycling bin, the paper window prints were printed on the work laser printer and the only cost [to me at least!] was a few squirts of PVA glue. It has proved a virtually zero-cost addition. The big investment was my time. This could be reduced with a better choice of glue as I spent more time on remedial work correcting warping and distortion than on the main construction. I'll have to see what alternative glues I can find and test.
alan_r
Postby alan_r » Sun Jun 09, 2019 8:16 pm
I made some more buildings for the edge background, this time of a simpler construction. Two consist simply of flat card with building prints stuck on, and the middle building is a flat expanded polystyrene tile covered in cardboard and another building print stuck to it. A larger polystyrene block forms a wider foot to the screen to stop it toppling over. The individual building pieces are stuck onto a backing card with double-sided tape to avoid the warping and distortion that always seemed to result from wet PVA glue. They certainly stick well and don't distort, but you only get one chance to position them with no adjustment afterwards, so accuracy and precision is key! The backing card (in white) can be seen protruding at the bottom - this is to catch the rear edge of the base to align it.
2½D building facades stuck to card background
The 2½-D screen takes away any flatness that a standard scenic backscene would have, yet it obscures the back and is in-keeping with the model when focusing on the trains and track.
Building background located onto the layout corner
Viewing the whole scene and it is looking much better. The gap between the two lines of buildings where the road passes between though is quite prominent, so I'll have to think of a way to close this off. Probably another narrow building and a sky print, maybe with a foot bridge to mask the road hitting a flat wall!
The office buildings corner
manna
Postby manna » Sun Jun 09, 2019 9:54 pm
G'Day Gents
Strange how we get used to small cottages and farms, on a model railway, office blocks and blocks of flats are a rarity.
manna
joshv8
Postby joshv8 » Wed Jun 12, 2019 1:07 pm
This is very, very clever. Well done mate
glencairn
Postby glencairn » Wed Jun 12, 2019 1:18 pm
Another layout with an individual style. Love it.
footplate1947
Postby footplate1947 » Wed Jun 12, 2019 5:48 pm
Post deleted as posted in wrong place
It worked last time I used it..............John
Lee
Postby Lee » Thu Jun 13, 2019 3:58 pm
Well done with the buildings they look very effective 8) :wink:
My N Gauge Layout.
