Hornby Pannier Tank
Hornby Pannier Tank
Hi All,
I want to know if the Hornby Pannier Tank comeing out with DCC. on board would be worth buying at 44 pound i would only be useing it on a small shunting layout.
Regards Terry,
Regards Terry,
- Essex2Visuvesi
Re: Hornby Pannier Tank
I would (and have) get the latest bachmann one
Runs lovely, look great and easy to fit the DCC
Proud member of the OAM
Seconded-I would reach a little urther to find the extra tenner.Had both & Bachmann's is nicer,better runner & excellent puller.
- Essex2Visuvesi
and the SL75 sound decoder from youchoose sounds the business. Needs no trimming to fit, just fit the speaker in the coal bunker
Seriously good advice. The Hornby Pannier was acceptable once but in comparison with the Bachmann offering it fades rather badly. Shop around, a late model Bachmann Pannier can be had for £40-45.
Tony
Tony
Unable to edit above post unfortunately - this was was split from a recent freight set and cost £42. No comparison !
![Image](http://i488.photobucket.com/albums/rr250/Cefnbryn/DSCF3450.jpg)
Tony
Tony
Hi All.
I have both of the Bachmann Pannier Tanks c/w TCS.DP2X-UK Decoders fitted, and as they are going to be used on a small shunting layout slow speed up to 20 scale 20MPH they run erraticly ,i have nipped out the supprers, set cv54 to12 and cv55 to62 and have tryed turning off BEMF and both still hesitate (Hunt).between speed steps.Now thasks for your help,i like the look of the Hornby Pannier and wanted to know how well it runs.
Regards Terry.![Sad :(](./images/smilies/icon_sad.gif)
Regards Terry.
I have a round half dozen of this Bachmann mechanism, including a couple of pannier chassis and several of the Jinty which shares the same design of motor and gear train. All smooth and reliable from a dead slow crawl on DC, using an old H&M clipper resistance controller, no BEMF assistance. Test your chassis on DC without a decoder, and if the decoder you use cannot match that performance then you will know it is time to look for something better. For myself, never a problem with Lenz standard decoders; these will operate this chassis as slowly and smoothly as anyone could reasonably desire, very close in performance to the much lower geared and flywheel equipped Bachmann and Hornby 08s ...
Thanks Bigmet the two Panniers were run in at my club on aH&M Clipper that was on a layout we were tissying up for a club Widow to sell ,Now sold , the locos both got 2 hours in each direction ,smooth as silk,only complaint was the speed they were capable of,i used these decoders as recomended on this Forum by a number members,Dad 1 Geoff has given me some settings to try,will give them a go on wednesday night at the club, ionly have APP,3ft of test track at the moment,timber and marine ply now in house ,time to start my UK 2ftx8ft Terminus Layout.
Regards Terry.![Very Happy :D](./images/smilies/icon_biggrin.gif)
Regards Terry.
I have the Hornby 2771 pannier, a 1970's 8751 pannier, and a bachmann pannier,
I have had the Hornby 2771 pannier for 6 years or so, it was ok to start off with, but over time it bacame a very erratic runner and gave up the ghost around 3 1/2 years ago, the body of the loco isn't too bad (doesn't have sprung loaded buffers), but is let down by a poor chassis (and traction tyres), and the chassis I have is not DCC ready (not an issue as I run DC)
although the 1970's pannier lacks the detail of the later body of both the 2771 and Bachmann pannier, the chassis is miles better and is one of the most reliable loco's I have
I agree with everyone else on the bachmann pannier, once run in as reccomended, it is far superior to what Hornby currently offer in both chassis and body, and it's worth spending the extra money, especially if you are running DCC
Hope this helps
Stu
Hope this helps
Stu
If You Can't Fix It With A Hammer......You've Got An Electrical Fault
Hi All.
Last night i tryed the settings Geoff suggested all fixed great improvement Collet Goods c/w DP2X-UK smooth as silk,56XX c/w T1the same Panniers c/w DP2X greatly improved,i think a little more running will help.
Now back to the Hornby new Pannier coming out ,no traction tyres good,DCC on board ,good ?,any body know if the chassis,motor, etc, have improved, i like the open cab on it ?
Regards Terry.
Regards Terry.
- Essex2Visuvesi
Funnily enough thats what puts me off the Hornby offering lolsiringe wrote:Hi All.
Regards Terry.![]()
The new Railroad chassis has problems traversing Peco set-track curved points (and sometimes other Peco/Hornby set-track points). If you search the archives you should find several reports of this. The problem seems to be a lack of articulation in the wheelbase causing the centre wheel to ride up slightly when passing through the frog - breaking contact on one side. It's a shame as they can be made to run reasonably on plain tracksiringe wrote:Now back to the Hornby new Pannier coming out ,no traction tyres good,DCC on board ,good ?,any body know if the chassis,motor, etc, have improved, i like the open cab on it ?
I have also had problems with the moulded brake shoes rubbing on the wheels - a bit too realistic! This is not helped by the often floppy bearings in the chassis. I have several Hornby 0-6-0s of various generations and my best runners are those with a re-wheeled sprung SSPP chassis. Of course the time and money spent in rewheeling them means that I would have been better off buying Bachmann 0-6-0's, but they don't make the half-cab pannier, J52, J83, E2 etc. which I have. If Hornby were to bring out a fractionally more articulated chassis with double reduction gearing and brake shoes slightly further from the wheels that could be nice runners
Nothing at all wrong with my Hornby pannier.....
![Image](http://i209.photobucket.com/albums/bb130/Limehouse-cut/2009-10-222009_1111_021310.jpg)
![Wink :wink:](./images/smilies/icon_wink.gif)
COLIN.
![Image](http://i209.photobucket.com/albums/bb130/Limehouse-cut/2bushey-railway-express-1-1-1.jpg)
Hi Bushey.
Looks like a golden oldy a bit like me , how does it perform.
Regards Terry.
Regards Terry.
