70000 on the Royal Train - 24th January.
Has anyone else noticed that this was running with the incorrect Royal Headcode? It is missing the lamp on the top bracket. Major oversight from someone there!
Camel Spotting Thread.
My layout thread.
My layout thread.
Re: 70000 on the Royal Train - 24th January.
Yes i noticed, i read the caption of the photo i saw it on and it said something about it, will try to find it.
60089 Felstead
Layout: http://www.newrailwaymodellers.co.uk/Fo ... 22&t=33128
Rail photos: http://www.newrailwaymodellers.co.uk/Fo ... 25&t=28381
I was once told that only the queen gets all 4 lamps, any other member of the royal family only has the 3 bottom lamps. Don't know how true that is. I know I wouldn't be volunteering to put a lamp on the top bracket while standing under the wires though.
I've not heard of that before, but that would also explain why 60163 was also missing a lamp on the top bracket when she conveyed HRH Prince Charles a few years back. I thought the three bottom brackets filled meant a through freight or mineral train...
My layout thread.
My layout thread.
- thebritfarmer
It appears all the headcodes should be 4
3 along the bottom and one on top, whether diesel or steam and stayed the same up until 1977
All Aboooooard !!
6024 only had 3 lamps on the bufferbeam when it hauled the royal train on the Severn Valley a few years back, but it did have the Prince of Wales headboad hung on the top lamp bracket
hope this helps
Stu
hope this helps
Stu
If You Can't Fix It With A Hammer......You've Got An Electrical Fault
