Point motors
Re: Point motors
Others say that the surface mounted point motors are notoriously difficult to fit accurately in position. Could take a lot of trail and error to get them fitted.
- hobby boy
Re: Point motors
AndyCott wrote:Quick update, The surface mounted point motors work perfecf when not attatched to the track![]()
There are faulty Surface Mounted motors around as i got a faulty one. It works on its own but isn't strong enough to power the point. The best thing to do is take it back to the shop and buy a peco surface mounted point motor - more reliable. Another thing you could do is make the point motors run off a seperate supply and use Passing Contact switches (hornby or peco) or return to centre toggle switches (on)off(on) Switches. If you decide to use them you need a CDU so it protects the point motors from burning out and give them a large push.
Andrew
I have this engine like the picture
GWR 0-6-0 Pannier tank
Check out Andrew's layout Hookstoke Junction UPDATED! Should do more work as it's now the Easter Holidays
After the holdiays are over, my layout won't get updated much Age = 15
Re: Point motors
Thank you everybody for your help, I have got them working today after spending 3 hours at it.
It's not a bald spot. It's a thumb mark!
Re: Point motors
The Elite provides more spare power than a Select due to its 4 amp power supply, but the Hornby accessory decoder stores up the oomph to fire the motors by way of a built in CDU, which isn't really that brilliant and the reason I stuck with analogue method of point motor firing using a Gaugemaster CDU and an old HM2000 controller for power. DCC is used only for the trains.
Even so they will fire 2 paired motors as long as the mechanical bits are nice and free, especially with surface mounted motors and are given a recharge interval between firings.
Tip for using PECO surface mounted motors with Hornby points - crop off a bit of the brass tube Hornby supplies with their Mk2 motors (shed mounted version) to join the extension pin to the motor and slip this over the Hornby point tie-bar. The Peco motor operating arm will fit nicely over the tube. A drop of super glue can be used to secure the tube to either tie-bar or motor but not both.
- Silver Surfer
Re: Point motors
Sounds like a friction problem Andy, so check the alignment. In my experience solenoid motors needed to be perfectly level and at a perfect right angle to the throw of the tie bar, the point itself had to be similarly flat and level, otherwise something would bind somewhere causing the solenoid not to throw.
The iron core in a solenoid is thrown along the channel when a momentary pulse of power is applied to it so it has to be free and easy to operate, but it won't push or pull anything with any weight or load and is usually just sufficient to flick over the centre spring which then locks the point in place. Because it doesn't have constant power, any additional load such as friction will prevent this from happening, whereas applying constant power burns out the motor so you end up with a lose/lose situation - that's why I use Cobalts.
Mike
Hawkers Bridge - A work in progress
__________________________________
'A Diesel engine is a machine - A Steam engine is a living being, almost human'
Re: Point motors
I got them working by lubing them with a bit of WD-40 on squirted into the motor and on the point *hinge* and tie bar, Also been in my local model shop today and spoke to Andy the assistant who's always been a helpful source of advice and was told they had problems getting the surface mounted motors on their shop layout to work until the were loosened up with some WD-40
Thanks to everyone who replied on this thread with help and advice.
Thanks again,
Andy
Thanks again,
Andy
Re: Point motors
WD-40 should never be used on anything model railways. It dries up quickly and leaves a yukky residue. Use lubricants especially designed for model railway use.
Re: Point motors
poliss wrote:WD-40 should never be used on anything model railways. It dries up quickly and leaves a yukky residue. Use lubricants especially designed for model railway use.
Oops, I'll clean up then and get some model railway lubricant then
Re: Point motors
AndyCott wrote:poliss wrote:WD-40 should never be used on anything model railways. It dries up quickly and leaves a yukky residue. Use lubricants especially designed for model railway use.
And then go back and strangle the other Andy.
- Silver Surfer
Re: Point motors
Silver Surfer wrote:Preferably not your local Retailer who more than likely will be intent on selling product and not necessarily giving you best advice.
Remember me suggesting this?
This is an example of very poor advice, not best - he wants locking up, firstly for ever suggesting WD40; secondly, for selling you kit that even they had difficulty with and they're supposed to be experts in the field.
Mind you if it was the dealership I'm thinking of then it comes as no surprise as I had some really dodgy advice from them when I went DCC - they told me their 'top-end' controller the Elite coupled with Hornby decoders was just about the best set-up you could buy. This might have been true of Hornby products but, there was never any suggestion of me doing any research nor the fact there were other manufacturers of DCC kit out there.... so double check anything they tell you and always compare prices before giving them your cash.
Mike
Ps. I think the fact WD40 loosened up the situation proves the 'friction' theory.
- Roger (RJ)
Re: Point motors
Silver Surfer wrote:Silver Surfer wrote:Preferably not your local Retailer who more than likely will be intent on selling product and not necessarily giving you best advice.
Mind you if it was the dealership I'm thinking of then it comes as no surprise as I had some really dodgy advice from them when I went DCC.
If it's the shop I'm thinking of (their name begins with a "G" and a "D"), I agree, there advice is based purely on how much they can make out of you. It's not what the staff like doing, it's management policy.
Edited for spelling
Re: Point motors
They have always seemed OK with me when I have been in the shop. But will proceed with caution now.
- Silver Surfer
Re: Point motors
AndyCott wrote:They have always seemed OK with me when I have been in the shop.
Nice guys but look what rubbish you've finished up with as a result of their OK'ness. I bet you also paid top dollar for what you got as well !!!!
Take a tip from me (it's free and a result of about 50 years in railway modelling - yes I know, that statement just makes me old but, hopefully, wiser
Tip: Stay away from this manufacturer's electronic and electrical gear - and I don't care what Andy or his cronies tell you as they're paid to inform you that the products they sell are the beez neez - but they're really not fit for purpose. The makers have now had three goes at DCC type systems/controllers, Zero1, Select and Elite, still can't get it right and all three of them are absolute dross compared to the serious contenders out there.
Unfortunately for you, me and everyone else, they have a name that was once a proud symbol in the model/modelling field, but they've had so much bad press over a ten or fifteen year period during which time they consistently got it wrong, that newcomers to the hobby are still drawn to the name and suffer as a result.
If you heed my advice (your choice entirely) you'll begin to enjoy the hobby much more and won't spend anywhere near as much time buggering about trying to get it all to work properly and also, be able to sit back and chuckle when you remember the bad old times when you used their kit and a Newbie comes on bemoaning their products.
For what it's worth, I know another dealer in the City who supposedly sells this make of equipment but, he's had so many complaints about their electronics kit, he simply refuses to stock it anymore and refers anyone with a complaint etc back to the manufacturer.
Roger(RJ)
I didn't want to name names, but now you mention it.....
Mike
Re: Point motors
Harping back to Hornby surface mounted point motors. If they are not perefctly aligned with the track mechanism the turnout tie bar pin can catch on the motor housing. Give the tie bar pin a bit of a file and it will stop it catching.
Re: Point motors
Silver Surfer wrote:AndyCott wrote:They have always seemed OK with me when I have been in the shop.
Take a tip from me (it's free and a result of about 50 years in railway modelling - yes I know, that statement just makes me old but, hopefully, wiser)
Roger(RJ)
Mike
all good advice from an elderly sage
