I have a Hornby Minitrix Spitfire Battle of Britain class in generally good condition. It ran but now does not run at all. Other engines run fine on the same track, so it's not a track or power supply problem.
I took it apart, cleaned the pick-ups, cleaned the wheels. If I put the chassis on the track, turn the power on and wiggle the chassis a bit, I get an occasional spark coming from what I believe to be the brushes. Does this mean the brushes are worn and need replacing? Can I get replacement brushes and replace them myself? They look pretty small and fiddly. Or is there a company which will trace the fault and return the loco to running order? I'm in Andover, Hampshire
Any help and advice will be gratefully accepted.
Hornby Minitrix Spitfire (brushes)
Re: Hornby Minitrix Spitfire (brushes)
Generically you should be able to do either
If you can find a supplier of replacement Minitrix parts then replace them, if you can access the means by which they are held in place. I would also at the same time replace any brush spring too if available and accessible.
These are AFAIK the main importers Mintrix spares
Or try one of the repairers such as The Engine Works in Canterbury Kent ....http://www.theengineworks.co.uk/welcome.htm
did minitrix do a spitfire?? i can't ever remember that model. but if it shares a similar design to the 9F or britania or A4 then the original motor can swapped out for a mashima 12x20 or 12x24 can motor with little effort. the biggest bind is getting the worm off the minitrix motor and boring it out to fit a mashima shaft. i remotored my A4 and 9F in this way. the worm goes on the brushes end of the can as the motor mount is through the backplate.
My apologies, it's Graham Farish of course. It's just that I've got it in a Hornby Minitrix box
ok, you should be able to get it sorted at BR lines, even if it means a new armature and brushes.
